EFI TO CARB
  • Thread starter Thread starter '88 5FOX
  • Start date Start date Nov 16, 2010
'88 5FOX
29
Seagrove NC
Nov 16, 2010
  • Nov 16, 2010
What are the pros and cons to a carb conversion. thinkin of doing one but I want to research it first.
bwguardian
50
Houston, Tx.
Nov 16, 2010
  • Nov 16, 2010
The carb will make a little more power on the big end. Seems like alot of work in an EFI car setup though.
'88 5FOX
29
Seagrove NC
Nov 16, 2010
  • Nov 16, 2010
problem is I'm getting tired of sensors, I can't run the cam i want because the car is speed density. Right now its burning rich as fire and getting around 12 mpgs
bwguardian
50
Houston, Tx.
Nov 16, 2010
  • Nov 16, 2010
If you can find an early factory 4180c carb you are better off as they are annular discharge. I rebuilt and tricked the one on my 85 vert and it is smooth like an EFI from 1,000 rpms up in 4th and 5th gears.
bwguardian
50
Houston, Tx.
Nov 16, 2010
  • Nov 16, 2010
It might be easier to convert to MAF.
'88 5FOX
29
Seagrove NC
Nov 16, 2010
  • Nov 16, 2010
i've got almost everything to do that with but someone hacked my o2 harness, before i can try that again i need to get one of those harnesses.
2000xp8
SN Certified Technician
Aug 8, 2003
8,073
1,656
194
NJ
Nov 16, 2010
  • Nov 16, 2010
pros-none
cons-setting up a good carb setup is not cheap, value will plunge on your car, you won't make any more power, good carb help is hard to find these days.
Back in the day carbs may have made a bit more power, but there are plenty of good intakes for 302 based engines now, and power difference for a street car is negligible.
Get your harness and maf setup sorted out, there really isn't anything easier to work on than an efi 5.0.
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
Best Ebay aftermarket Radio/screen
  • Shurkeel
  • Oct 8, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 9, 2026
gkomo
R
Efi to car pcv HELP !
  • rgrendell
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
M
1985 v6 to v8 carb swap
  • mgriffin_2222
  • Mar 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 9, 2026
mgriffin_2222
M
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
