efi trouble
  • Thread starter Thread starter brent35967
  • Start date Start date Aug 7, 2005
brent35967
  • Aug 7, 2005
i have 1988 GT speed density it is gas fouling the plugs ,flooding real bad.anyone ever had this trouble?
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Aug 8, 2005
  • Aug 8, 2005
You could have leaking injector(s), a bad MAP sensor or a fuel pressure regulator with a leaking diaphram or any combo of the above.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 8, 2005
  • Aug 8, 2005
Follow Tmoss's advice, if you don't find any thing wrong after doing what he says, try this...
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
Cylinder balance test:
Warm the car's engine up to normal operating temperature. Use a jumper wire or paper clip as described above to put the computer into test mode. Start the engine and let it go through the normal diagnostic tests, then quickly press the throttle to the floor. The engine RPM should exceed 2500 RPM's for a brief second. The engine RPM's will increase to about 1450-1600 RPM and hold steady. The engine will shut off power to each injector, one at a time. When it has sequenced through all 8 injectors, it will flash 99 for everything OK, or the number of the failing cylinder such as 22 for cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause the test to re-run with smaller qualifying figures. Do it a third time, and if the same cylinder shows up, the cylinder is weak and isn’t putting out power like it should. See the Chilton’s Shop manual for the complete test procedure
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
Y
Speed density 302 to carb 351W
  • yaboity
  • May 29, 2026
  • Fox Engine Swaparoo
Fox Engine Swaparoo May 29, 2026
AeroCoupe
J
Greetings from Central Florida!
  • JediMeister
  • Thursday at 9:40 PM
  • The Welcome Wagon
The Welcome Wagon Friday at 4:06 PM
Rdub6
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
Electrical Spark Plugs
  • jimzzilla
  • Feb 24, 2026
  • 2 3
Fox 5.0 Mustang Tech Feb 28, 2026
jimzzilla
