Egr and Idle bypass Control
latham83
496
Hey i have my car all ripped apart getting new **** for it..
and i was just wondering...my smog pump and tubing is totally gone i ripped it all out...What bout my EGR and the long thing on the side of the throttle body its called th Idle bypass whatever..I have 165,000 on em and i hear they go bad...they are expensive..and i dont know if i wanna replace them??? who knows if they are even working..this summer before i did alot of mods my car would idle rough..I'd start it up and then it roar but then fall like it was going to stalll..and then pick back up...and then evetualy evened itself out..is it one of these 2 stupid things..also when my check engine light was NOT on but i wuld pull codes and one would come up..it was 33 or 34..related to the egr..i bought a new sensor for it, but didnt solve the prob. code was still there..can i delete both of these stupid thigns?? or just buy new ones..whast the deal
Code 34 EGR voltage above closed limit - Failed sensor, carbon between EGR pintle valve and seat holding the valve off its seat. Remove the EGR valve and clean it with carbon remover. Prior to re-installing see if you can blow air through the EGR valve by mouth. If you can, replace the EGR valve ($85-$95).
The computer controls the idle speed by using the IAB. The IAB costs about $40. Make sure that the EGR is working properly and that you don't have any vacuum leaks before you replace it. Usually cleaning it and the throttle body with throttle body cleaner is all that is needed.
