egr hose question on explorer intake
mob
the guy who hits on his mom
Oct 3, 2003
2,566
136
104
Dallas, TX
Hey guys. On the stock intake the hose comes from the back of the intake up to the egr spacer, and comes back out another hose. I installed my explorer intake and realised that it dosent have that tap. (have gotten the act tapped i wish i would have gotten that tapped aswell.) but anyways. Is it ok to just cap off the egr stem things that come out the egr spacer? I know itll be ok, but ive heard some people say ill loose hp. Ive heard other people say it wont make a difference. And if heard pople say its to heat up the air coming in on cold start ups? Not sure whitch one it is, dont really care, just wanna know will I be hurting my gain from the intake if i dont have coolant through the egr spacer? Would it be better to delete the egr? thanks.
You can just block off the EGR passage and you will be fine.
Go to the auto parts store and buy a rubber expandable plug. I think the size is 5/8" IIRC. (Around $1.50 or so.)
It is a rubber type of plug with a washer on the top and bolt going through it.
You push it in here and tighten it until it is snug.
It kind of looks like this but with a bolt going through it instead of the copper peice on top.
It only comes with one washer on the top side so you will need to get another washer for the bottom side to keep the heat from getting to the rubber.
I have used these on several cars for the last 15 years or so and they work like a champ for blocking the EGR off.
You can usually find them on one of the isles near the bolts.
I have even pulled intakes off 5 years later and the pulg was still fine.
Or you could tap it and buy a brass plug to plug the EGR passage off.
Either way you don't need the coolant running up to the EGR if you block off the port.
Another alternative would be to buy a phenolic intake spacer. They have the EGR port blocked but they cost more money.
Good luck.
i had the same thing happen to me.i had the act tapped and found out there was no egr return line oops.since i had not ran the motor yet and i was in no rush i removed it and just had the shop tap the hole in the stock location. phil
If you had used the explorer heater feed tube, your problems would be over. It has both the source and return lines for the EGR spacer. The ECT sensor will be a little difficult to install, so it is installed before you install the heater feed tube.
If you had PM'd me before you started, I could have stopped by and given you some pointers. I am running an explorer intake with everything hooked up & working, including all the EGR stuff. Winter Springs is 15 minutes from Chuluota.
i got mine all installed, and then discovered i too had forgotten to drill/tap the egr coolant return. but i noticed that the egr nipple in the heater core tubes was in the one tube, and the ECT sensor was in the other tube. so, i got a brass tee and ran the egr coolant return back into the tube where the ECT mounts. it looks kind of funny, but its probably the cheapest / easiest solution.
you can kind of see it in this pic. and no, it doesn't hit the hood.
I appreciate it but there was absolutly no way I could have known..... To do that heater feed tube would I have to take off the upper intake?
