  • 1994 - 1995 Specific Tech
EGR Nut question.
  • Thread starter Thread starter 2003 mustang gt modded
  • Start date Start date Aug 29, 2024
120
Florida
Aug 29, 2024
  • Aug 29, 2024
Hi, Searched can not find answer.
What way does it turn? I know that different makes/models it turns opposite.
Also is there a special handyman way to get that huge nut off? It's suezed on there.
Thank you.
AeroCoupe
5,796
3,928
183
Claremore, OK
Aug 29, 2024
  • Aug 29, 2024
So starting another thread can sometimes not be the best way to get the info you want. You can simply change the title on the first thread and then those that read it get all of the back ground. Just wanting to point out that you can change the title.
O
Opal GT
14
Central New York
Aug 31, 2024
  • Aug 31, 2024
Lefty loosey righty tighty, just remember on the valve you're looking at it upside down. Are you asking about the nut on the valve itself or in the header?
120
Florida
Sep 1, 2024
  • Sep 1, 2024
I would like to find out for both upper and lower, I think if upper nut is really stuck on there , then loosening lower one will reduce risk of braking tube.
O
Opal GT
14
Central New York
Sep 1, 2024
  • Sep 1, 2024
The best way I've found over the years is to unbolt the EGR from the intake then loosen the tube from the header with a crowfoot. I have a small set of torches and use a brazing tip to get a little heat on it. Then put the EGR in a vise to loosen the tube from it. Still broken a few in my time.
120
Florida
Sep 1, 2024
  • Sep 1, 2024
Opal GT said:
The best way I've found over the years is to unbolt the EGR from the intake then loosen the tube from the header with a crowfoot. I have a small set of torches and use a brazing tip to get a little heat on it. Then put the EGR in a vise to loosen the tube from it. Still broken a fem in my time.
If you run with EGR blocked that means your combustion is higher temperature? Can that damage engine?
120
Florida
Sep 2, 2024
  • Sep 2, 2024
So both upper and lower are non reverse threads?
O
Opal GT
14
Central New York
Sep 2, 2024
  • Sep 2, 2024
Yes, turn left to loosen and right to tighten.
120
Florida
Sep 2, 2024
  • Sep 2, 2024
Got it, thanks.
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
Rear quarter window regulator
  • BADAZZOMBIE08
  • Mar 29, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 29, 2026
BADAZZOMBIE08
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Monday at 12:39 PM
nickyb
D
Help--Need New Exhaust Gas Recirculation (EGR) Tube for 1994 V6 3.8 L Mustang--where can I find one?
  • DPP
  • Jun 5, 2025
1994 - 1995 Specific Tech Jun 10, 2025
DPP
D
Sn95 new style hub retaining nuts
  • limp
  • Mar 6, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 7, 2025
limp
