egr valve
  • Thread starter Thread starter 87_GT
  • Start date Start date Nov 3, 2005
87_GT
179
tinley park, illinois
Nov 3, 2005
  • Nov 3, 2005
i am getting my car ready to be sold and i need to fix my check engine light. it is the insufficent egr flow one. i pulled the egr valve assembly thing and was wondering if there was a way to test it? i really do not want to spend $100 on this part. also, could i hook up a vac. tester to the green vac line that goes to the valve? if i did that what should the reading be. thank you
HISSIN50
34
129
Nov 3, 2005
  • Nov 3, 2005
I just had the one on the SN out today for a cleaning. You can apply 5" of vac to the nipple to see if the diaphram moves. I stood in a mirror and sucked on it and watched its movement - pretty good range.
If the flow is insufficient, chances are the valve is all coked up with carbon. I sprayed mine out and then put carb cleaner in it (filled up each port) and let it sit and soak.
The other possibility is that the EVR is not calibrated. This can happen if the EGR valve seat wears.
JRichker has the complete run-down on full testing of it. This is just my tired thoughts.
GOod luck.
87_GT
179
Nov 3, 2005
  • Nov 3, 2005
thanks for the reply. i will try sucking on it since i dont have one of those hand held vacuum things. if that seat wears, do i just have to buy a whole new egr valve?
HISSIN50
34
129
Nov 3, 2005
  • Nov 3, 2005
You can either get a new valve or you can adjust the EVP's sensor so that it baselines (zeroes out) with the new seat height. That is kind of a pain though (you keep playing with it till it works).
A good cleaning might take care of it alone (and making sure the diaphram is not ruptured when you suck on it).
I forgot to check your sig (I am in the quote reply page right now), but you dont have a real (illuminated) CEL, right?
Good luck.
HISSIN50
34
129
Nov 3, 2005
  • Nov 3, 2005
Ok, got it. This is on an SN. It really takes 3 minutes to get the EGR off. FYI, I had to soak the feed-tube threads in PB blaster before I could get the fitting loose. Then two bolts and off it is. Make sure the gasket looks ok or have a spare ready.
Good luck.
87_GT
179
Nov 3, 2005
  • Nov 3, 2005
it is a 1995 so the cel does illuminate. how do you adjust the evp sensor? and i already have it off
HISSIN50
34
129
Nov 4, 2005
  • Nov 4, 2005
I will have to look up the info on that since it is for an SN and there may be differences (it is SO unlikely, I will hold off. You are not spitting the right code for it. Since the SN's have better processors, it would likely spit the correct code).
Otherwise just make sure the valve is really clean and that all the connections are clean and good to go. A bad ground on the EVR connector will toss a limit code (which you dont appear to have anyhow).
Those passageways should be fairly healthy - a straight brush should remove carbon in the 90* bend (I did not have one of those brushes on hand so I could not clean it as well as I wanted. A toothbrush does not fit down one of the passages very well).
In its dynamic, you should be able to check the values at the connector (VRef, signal, ground) and make sure the right signal are being sent. At that point you can see if the sensor is calibrated too (see if the signal reading is off)
Though the passageways many not puke out lots of filth (mine didnt), cleaning can 'unhang' the pintle's movement. There is not much vac to that diaphram, so getting it unhung is important (so it actuates real smooth). That really might take care of it.
Good luck.
87_GT
179
Nov 4, 2005
  • Nov 4, 2005
thanks a lot for all the help
jaymac
995
Northern Mass
Nov 4, 2005
  • Nov 4, 2005
You're the man!!!!!!!
A
Acid7711
41
TN
Nov 4, 2005
#10
  • Nov 4, 2005
  • #10
I'm having the same problem on my '89 GT. I've cleaned it out good. CEL came back. Checked the wires, the voltages seem fine. How do I go about adjusting the baseline? I'm tired of constantly having the CEL flash on and off at random times for "insufficient flow".
Thanks.
87_GT
179
Nov 4, 2005
#11
  • Nov 4, 2005
  • #11
i was unable to fix the problem, so i went out and bought a new valve and the position sensor, went to take her around the block and the check engine light popped back on. so my i am now thinking that the vacuum line is prabably bad. if i hook up a vacuum gauge to the end of the green line goin to the valve, what should the reading be?
HISSIN50
34
129
Nov 4, 2005
#12
  • Nov 4, 2005
  • #12
Jeremy, you're sick!
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 4, 2005
#13
  • Nov 4, 2005
  • #13
"I stood in a mirror and sucked on it and watched its movement - pretty good range."
Aw, c'mon JT - save that stuff for those other sites you frequent....and stay away from my wife.
What in the world were you thinking when you typed that? I'm ROFL......
HISSIN50
34
129
Nov 4, 2005
#14
  • Nov 4, 2005
  • #14
Look at what time I typed it. Normally I catch it when I type something like that - not this time.
Normally it would not be a problem to say something like that - it is you guys who have your minds in the gutter.
Or maybe I just like to brag (and make my dog feel less superior).
It is not as bad as the guy who had a thread title asking for Grady to look at his log.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 4, 2005
#15
  • Nov 4, 2005
  • #15
With prose like that, it's not a long reach to the gutter -- there, I used 'long reach' just for you.
18mustangs
533
Virginia Beach, VA
Nov 4, 2005
#16
  • Nov 4, 2005
  • #16
You may be able to find a good EGR valve on Ebay for a cheap price...I did and it works great.
Tim
jaymac
995
Northern Mass
Nov 4, 2005
#17
  • Nov 4, 2005
  • #17
I don't know if you noticed, but I added your ill-conceived quote to my sig, but I thought you might get offended by being immortalized to all as the member who "stands in the mirror and sucks on it"...so I took it out....
Oh well, it was fun while it lasted.
Oh yeah, and stay away from my fiance, too...
And my dog
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 4, 2005
#18
  • Nov 4, 2005
  • #18
You're scaring me jaymac -- I was gonna post it as a poll (pole!) thread like so:
The following quote --- "I stood in a mirror and sucked on it and watched its movement - pretty good range." refers to:
A) How a lonely, but well endowed guy with low self esteem spends Friday night (well, every night)
B) Guy testing the viscosity of his favorite 'make it thicker' milkshake
C) The proper way to check the function of your egr valve
D) Someone practicing their gas-siphoning technique
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Engine Stock TB - smoke test - leaking bad
  • R82148V
  • May 18, 2025
2K
Fox 5.0 Mustang Tech Jun 5, 2025
R82148V
