Eibach or H&R???
  • Thread starter Thread starter two_stangs
  • Start date Start date Mar 1, 2004
two_stangs
61
AZ
Mar 1, 2004
  • Mar 1, 2004
I'm getting springs for my Hatch. I don't want it slammed. Just lower it a little over an inch.
The choice's are:
H&R sport springs
Eibach Pro-Kit
It has KYB GR-2 Struts And Shocks. Also Has Saleen Racecraft Quad Shocks.
And AFS wheels Cobra Rims 17x8 Front and 17x9 Rear.
They lower about the same. Is there a difference in the kits? I know Eibach is Great from experience and I know H&R is great from experience. But they were not on a Mustang.
Are there any pro's or Cons?
ALMOST STOCK
1,250
41
88
CA.
Mar 1, 2004
  • Mar 1, 2004
I went with H&R Sport Springs 4 yrs ago, they lowered the car 1" and it's still at that height today.
two_stangs
61
AZ
Mar 2, 2004
  • Mar 2, 2004
What is the offset of your rims?
Do you have any rubbing problems?
I'm leaning toward H&R springs as well. Your car looks great. It's at a very nice height. Very clean looking.
ALMOST STOCK
1,250
41
88
CA.
Mar 2, 2004
  • Mar 2, 2004
The offset is +28 (5-7/8")
I had a very slight rubbing issue at full lock the rims rubbed slightly on the A arms. I installed a $5 clip and I've never had a problem since.
Thanks for the complement.
TheRedBlur
15
seattle
Mar 2, 2004
  • Mar 2, 2004
go H&R man, they are the best
M
Muirracing
23
Louisville Ky
Mar 2, 2004
  • Mar 2, 2004
wheels
you said u are running a set of cobra's the frt are 17x8 I was wondering what type a tire u running on that wheel?
im actually thinking about ordering a set a bullets i was going to go with 17x9
with a 5.78 back spacing....
after reading ur comment I think i should goi with the 17x8 up frt
WHAT U THINK ????
and please let me know what size tire u running out back as well..
Thanks,,,, ... Ron ...
two_stangs
61
AZ
Mar 3, 2004
  • Mar 3, 2004
WHAT U THINK ????
I got a set of AFS Wheels Cobra R's style 4 lug
They are 17x8 +12mm offset up Front 4.95 backspacing
And 17x9 +24mm offset in the Rear 5.95 backspacing
The Fronts Don't rub at all. The Rear were real close to the Quad shocks. So I bought a thinner set of Saleen Racecraft N2 Quad shocks and had no problems after that. I got over 3/4 of an inch clearance with them.
AFS also put 255/40/17 Tires on them. Up front and in the rear. I don't like that size up front on the 17x8's. They are to tall and should not be on the 8inch wide rim. But they fit. I will be getting 235/45/17's up front when I lower my car with the H&R springs so I don't run into any rubbing problems at all.
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
F
For Sale 03 Redfire Cobra Convertible
  • FastFox5oh
  • Jul 14, 2026
SN95 Mustangs For Sale (1994-04) Jul 14, 2026
FastFox5oh
F
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Suspension A not-so-low lowering spring
  • Justin87
  • Mar 7, 2024
4K
Fox 5.0 Mustang Tech Mar 12, 2024
Justin87
Suspension Rear driver side sits lower than rear passenger side...?
  • 91GTstroked
  • May 15, 2024
3K
Fox 5.0 Mustang Tech May 18, 2024
91GTstroked
