Eibach Pro Kit Problem
blackstang351c
69
Indy
I just installed an Eibach Pro kit on my '05 Vert. I checked the factory jack and it does not go low enough to use if I should have a flat. Does anyone have a solution for this? Anyone else run into this?
You might try going to your local auto parts store and see if one of there small hydraulic floor jacks will fit under your car. Some are made fairly small, not too expensive, and will fit in trunk easily. Worth a try anyway. I have Sportlines on my vert and could not go thru a carwash that I frequently go to. So I can imagine the probs your going to have with the Pro's. Probably looks good though :-)
Bill
Bill
Well... Not being able to go thru a carwash might very well lengthen the life of your paint.
blackstang351c said:
I was hoping not to have to carry lumber around with me. Guess I'll hit the junkyard. I'll let anyone interested know what I find.
Was just thinking of when I change my oil. Good point. If you ever get in a jam, you could use anything to drive upon....A rock, road trash, junk in your car, a med stick, roadkill, or you could just call roadside assistance that usualy comes with the warranty. Other than that you can just admire how well your flat tire looks on a lowered car....oh well. :shrug:
