  • SN95 4.6L Mustang Tech
Eject!
  • Thread starter Thread starter Mach1Run
  • Start date Start date Sep 28, 2004
Mach1Run
333
Wylie, Texas
Sep 28, 2004
  • Sep 28, 2004
Anyone know how to get the CDs out of a Mach 460 after it says, "CD Error"? I was listening to the cd player on the way to work and when I got in the lot I tried to eject one of the CDs and got the error message. Now I cant even listen to the CD, change to another CD, or eject the current one.
Back2Mustangs
466
  • Sep 28, 2004
IF this is an emergency...
I haven't had that happen so the first thing I would do is either pull the fuse then put it back or disco the + battery cable for a few seconds then re-attach it. Doing either should blank out the radio(clocks and presets also) But you may want to wait until someone else posts that maybe has had this same problem....it might take something really easy to get it to spit your CD out.
stang976
853
Westchester, NY
Sep 28, 2004
  • Sep 28, 2004
no no no. slip a credit card in their carefully and nudge the cd up and it will spit it out. common problem.
PS-talk nice to the mach stereo while atempting
A
Ajax_02GT
90
Austin, TX
Sep 28, 2004
  • Sep 28, 2004
Mine did that a few months ago. It seemed that the CD was getting hung up when trying to eject. I could see the edge of the stuck CD so I just used a key/small flat screwdriver/another CD to lift up on the edge of the stuck CD to free it.
Back2Mustangs
466
  • Sep 28, 2004
Aaah
So what you guys are really saying is he needs to replace the head-unit with a nice aftermarket one!
My problem-solving perspective = Have a lose screw...replace half the car.
stang976
853
Westchester, NY
Sep 28, 2004
  • Sep 28, 2004
Back2Mustangs said:
My problem solving skills = Have a lose screw...replace half the car.
im the same way
seany425
90
  • Sep 28, 2004
it seems to happen with copied cd's alot with labels on them, i ussually use my plastic parking tag since its conveniantly hanging on the mirror but anything thin will work and it will come right out
M
mrpositraction
296
Columbia, MO
Sep 28, 2004
  • Sep 28, 2004
Happened to me also, I took a knife and nudged the CD till it came out,
I did not talk nice to it though, I talked dirty to it. I think it likes it. Then I decided to upgrade the whole system. I am such a playa
apk1971
133
Upstate NY
Sep 28, 2004
  • Sep 28, 2004
I had it happen with a Pink Floyd CD. It seems to be just a bit thicker than most CDs. I used a calling card/credit card to get it out. Slide it between the top of the CD and the mechanism that it is stuck in and with a little downward pressure, it should slide out. Then rememeber what CD it is and don't use it in the stang again...
Good Luck.
Mach1Run
333
Wylie, Texas
Sep 28, 2004
#10
  • Sep 28, 2004
  • #10
will go take a look at it in a minute and see if i can see it. It was too dark last night and this morning to see anything.
Heh once i save up some i probably will try and find a new head unit but since i just bought the catback im kinda low on funds. =)
Indiana
286
#11
  • Sep 28, 2004
  • #11
Happens to me all the time.
apk1971
133
Upstate NY
Sep 28, 2004
#12
  • Sep 28, 2004
  • #12
I only had it happen once. IMO the problem is with the CD, not the head unit...
Mach1Run
333
Wylie, Texas
Sep 28, 2004
#13
  • Sep 28, 2004
  • #13
poked at it with a my work ID and it came out. I went ahead and tried to eject the other 5 adn 3 of em hung up. They do seem to be the ones with the slighty thicker labels even though they are originals not copies.
2001geetee
24
Los Angeles
Sep 28, 2004
#14
  • Sep 28, 2004
  • #14
This happens to me all the time...and I do the same thing. You can also substitute the credit card with another CD, or anything else flat.
Skidawg
104
#15
  • Sep 28, 2004
  • #15
Yeah, it's a common problem with a CD with a label on it. Power clycling the accessory switch usually gives you another shot at ejecting the CD. I usually just slide another CD on top and drag the stuck one out. Big nuisance first time, but once I got the trick, it's no problem.
Hammer1999Gt
169
Toledo, OH
Sep 28, 2004
#16
  • Sep 28, 2004
  • #16
buy a new head unit it fixed my problem
tomustang
Psychotic Member
3,434
McLean Hospital
Sep 28, 2004
#17
  • Sep 28, 2004
  • #17
same here, one of my lights blew on the cd player so i replaced it with a clarion setup + new speakers everywhere.
kurst
764
New Orleans, LA
Sep 28, 2004
#18
  • Sep 28, 2004
  • #18
IMO, if you have to be careful of the thickness of your CDs or if your CDs have labels on them before you stick them in your player~ the problem is with the player.
I've had the cd error message, i banged, i turned off the car, when i came back in the morning it had puked it out by itself.
SJB Parasitic Draw, Fuse 59&67
  • 2005 Mustang V6
  • Apr 30, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 29, 2026
boatillo
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
N
Thermostat housing
  • nataliaisafraid
  • Dec 8, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Apr 2, 2026
Cmrd
C
Long Time Coming
  • 85gtCOBRA
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 18, 2025
2Blue2
