El Stango Idling Too Low
xj220
696
It's about a 100 to 200 rpm lower at idle than it used to be. What adjustments would I have to do to raise the idle again? Its a 289 4 barrel. Thanks for any help.
definately depends on your cam. my car needs to run at about 900 and even then it likes to stall when warm or cold when stopping at a stop sign. i just love the way the cam sounds at about 900 rpm's when idling. but yes around 650 to 750 when fully warmed up with an auto. make sure your car is completely warm and the choke is disengaged before you try and set the idle, otherwise you will be way off with the fast idle choke running. that can also be set, but by another carb specific way
