Electric fan controller wiring with relay?
  • Thread starter Thread starter paczowski123
  • Start date Start date Dec 18, 2012
P
paczowski123
76
Atlanta, Ga
Dec 18, 2012
  • Dec 18, 2012
I'm going to be starting on my electric contour fan upgrade here shortly and I wi be using a fan controller and a relay but I'm a little confused on how the wiring will work using the controller and the relays. Does anyone have access to well described write up of where to wire in the relays in relation to the controller and fan etc? I'm assuming since the fans pull so much curren they cannot be ran directly off the controller And would need to trigger a relay using the controller but I cannot think of how I would do this? Would I just wire the relays into the signal wire off the controller that would normally go to the fans etc? Any help or diagrams would be greatly appreciated!
MikeH686
Mine is only two inches though.
2,843
1,753
184
Waldorf, MD
Dec 19, 2012
  • Dec 19, 2012
You would wire the controller in series with the signal or trigger wire that powers the relay that sends power to the fan... make sense?
P
paczowski123
76
Atlanta, Ga
Dec 19, 2012
  • Dec 19, 2012
Yes I'm just trying to picture how I'd do that. In the diagram in this link I'm assuming its go in series with the red and black wire that go to the fan:
http://www.gearheaddiva.com/3031/how-to-wire-your-electric-fan-controller/
But what would I connect the other three prongs to on the relay? That's where I get confused it what all the prongs on the relay would connect to.
MFE92
1,094
373
124
Phoenix
Dec 19, 2012
  • Dec 19, 2012
If you're using the controller explained in those instructions, you don't need a relay at all. The controller serves as the relay.
That said, if you're using another setup that does require a relay, the "Bosch style" relay terminals are universally consistent. Terminals 85 and 86 are your low-current inputs, the ones from the switch you're using to control the circuit. It really doesn't matter which one you treat as positive and which one you treat as negative. Terminal 30 is your high-current input, the one that will actually power the device you're switching, usually Battery Positive. Terminal 87 is what you connect to the device you want to power. So, when you (or the temp sensor) flip the switch, 85 and 86 get current, which energizes the relay and closes the circuit between 30 and 87, and your device comes on.
P
paczowski123
76
Atlanta, Ga
Dec 19, 2012
  • Dec 19, 2012
So would a controller such as that one or the one I'm looking at is the FAL variable speed one that has soft start not need a relay? Don't the fans for te Taurus or contour pull a lot more than 30amps which is what most of those are rated for?
MFE92
1,094
373
124
Phoenix
Dec 19, 2012
  • Dec 19, 2012
No, the FAL VSC does not need a relay, and its soft-start feature wouldn't work through a relay anyway. It works by pulse-width modulation, so it's sending short bursts of power for a second or two until it sends full power. That's no way to run a relay. FWIW I run one with a Contour fan with no trouble at all.
P
paczowski123
76
Atlanta, Ga
Dec 19, 2012
  • Dec 19, 2012
Oh we'll then that takes away much of my confusion then. Thanks for all the help! I will venturing to the local pull a part here in a few minutes to try and track a fan and a 3G down. Hopefully I'm in luck!
P
paczowski123
76
Atlanta, Ga
Dec 19, 2012
  • Dec 19, 2012
Im assuming the controller your using is the FAL 31165 which used the soft start and to 60-100% cycle? Was it fairly easy to set up and get functioning properly?
P
paczowski123
76
Atlanta, Ga
Dec 19, 2012
  • Dec 19, 2012
Success!!Scored what looks to be a almost new replacement remanned 3G from a 96 tortise 3.0 and my cooling fans from a contour in great shape! Even checked the part # from autozone and it is indeed a 130 amp! now just got to order the controller and my radiator and ill be ready to install!!
MFE92
1,094
373
124
Phoenix
Dec 19, 2012
#10
  • Dec 19, 2012
  • #10
I'm using the 33054 which is the controller in the 33165 kit. Or something. Same controller. Yes, it's pretty easy to set up.
http://forums.corral.net/forums/articles/898470-installing-taurus-fan-vsc-5-0-a.html
http://forums.corral.net/forums/gen...01-taurus-fan-flex-lite-33054-vsc-how-do.html
P
paczowski123
76
Atlanta, Ga
Dec 19, 2012
#11
  • Dec 19, 2012
  • #11
Well it seems I will be going back to the yard again in the next day or so. I tested the fans once home jumpers from a spare battery I had laying around and only one fan came on. Luckily I bought the 3.00 39 day warranty. Unless I'm missing something and one of the fans won't work when connected straight from battery + and - or has to run off the other fan being connected than the larger of the two fans in my setup does not work
A
adumb
108
#12
  • Jun 2, 2015
  • #12
Good info in this thread. I was having a little confusion about using a relay with the vsc but the explanation makes sense why I don't need one.
Does it matter if you put the power and ground wires directly to the battery? I have my power to the hot side of the solenoid and my ground to the frame behind the battery
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 2, 2015
#13
  • Jun 2, 2015
  • #13
For those of you not familiar with the term pulse width modulation, here's an explanation
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Engine Contour fan CFM
  • Mustang5L5
  • Apr 6, 2026
Fox 5.0 Mustang Tech May 22, 2026
qikgts
Electrical Key on power for Fan relay
  • Nine Finger Wrenching
  • Jan 14, 2025
Fox 5.0 Mustang Tech Jan 20, 2025
F
AC Compressor Power & Contour Fans
  • Fri Guy
  • Aug 27, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 15, 2026
BoostedRed89gt
