electric fan relay
  • Thread starter Thread starter fordmuscle395
  • Start date Start date Aug 5, 2008
fordmuscle395
114
Sumter, sc
Aug 5, 2008
  • Aug 5, 2008
what electric fan relays or wiring kits are you guys using? Which ones do you suggest?
R
Rick James
172
burlington new jersey
Aug 5, 2008
  • Aug 5, 2008
I myself am about to get started on upgrading to a e-fan and have seen some decent relay kits from Jegs and Summit racing that are pretty cheap and include a screw in thermal switch,just make sure the relay kit can handle the amp draw of whatever fan you are going to run.
S&B
I hate my CT. :(
1,634
695
204
Cheesehead
Aug 5, 2008
  • Aug 5, 2008
buy a DCC controler and live life
HISSIN50
34
129
Aug 5, 2008
  • Aug 5, 2008
Another Dc Control endorsement.
S&B
I hate my CT. :(
1,634
695
204
Cheesehead
Aug 5, 2008
  • Aug 5, 2008
just dont expect the thing to arrive 2 days after you order it, mine took like 3 weeks, but it was well worth the wait
IH8BOWTIES
92
Aug 5, 2008
  • Aug 5, 2008
I bought the whole fan with relays and wiring kit from texas mustang. 2800 cfm and what I really like about it is that it mounts to the stock shroud. After the install it looks like it came factory with an e-fan. http://www.parts123.com/parts123/yb...~S2FM19L0MC98162122336d~Z5Z5Z5~Z5Z5Z50000081a
It was 105 here today and my car never got over 205. Works great.
fordmuscle395
114
Sumter, sc
Aug 6, 2008
  • Aug 6, 2008
That kit from Texas mustang looks bad ass, where can I find the DCC controller?
HISSIN50
34
129
Aug 6, 2008
  • Aug 6, 2008
fordmuscle395 said:
...... where can I find the DCC controller?
Instructions for ordering
IH8BOWTIES
92
Aug 8, 2008
  • Aug 8, 2008
To be quite honest, I'm not sure about a DCC but this kit came with everything I needed. Temp sensor, both temp and A/C relays and all the hardware. The only problem I had was installing the temp sensor in the aluminum water inlet. Very easy to overtap (tap included in kit) then the sensor tends to strip it when intstalling. I did this so I went with a cast iron inlet. Also use butt connectors instead of quick disconnects as the latter can't handle the heat and they melt.
130 amp alternator is a must. I continued to have a discharge problem in town so I did away with the underdrive pulley and went back stock. E-fan has a bigger power advantage than underdrives do anyway. This fan performs and looks great.
R
Rick James
172
Aug 8, 2008
#10
  • Aug 8, 2008
  • #10
Hey do you have any pics of it installed,for the price it doesnt look bad.
fordmuscle395
114
Sumter, sc
Aug 8, 2008
#11
  • Aug 8, 2008
  • #11
I will probably go with the texas mustang setup, I aint gotta track down any parts. its all there, no guesswork!
HISSIN50
34
129
Aug 8, 2008
#12
  • Aug 8, 2008
  • #12
You live in Vegas if I read your location correctly. The OEMs (Ford, GM, etc) do desert testing just to be sure their components can handle 120*F days, etc.
If you want a proven kit, get a new or used OEM cooling fan (Mark VIII, etc) and a Delta controller (which includes all the wiring, connectors and so on) and you'll have an outstanding fan and fan control that cannot be matched.
There's no comparing on/off switching and relays versus a PWM controller. You might even save some money if you can score a fan for cheap.
FWIW, This is not a bash on that kit but rather just MHO.
Good luck.
fordmuscle395
114
Sumter, sc
Aug 8, 2008
#13
  • Aug 8, 2008
  • #13
well.....I reckin i could look into DCC more, cause i got a 3.8 fan out of a mustang back home, hmmm...I never heard of em till now.
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
U
No fuel pump relay in harness
  • Uli661
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
Uli661
U
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
2010 GT AC issue
  • 2010torchredgt
  • Jun 28, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jun 29, 2026
2010torchredgt
Resolved Holley terminator integration into CCRM
  • BrandonMP
  • Feb 25, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 23, 2026
fasterthangas
F
