electric fan wiring (a/c)
grippper
494
what wire do i tap into on the ac,and how. can i use a wire tap. im using a delta curent controler.also im running duel fans so do i just use wire taps to hook into the fan i have hooked up to the controler.
What exactly are you trying to do? Is it to make the fans come on when the A/C turns on? Have you checked the manufacturer's web site for deatils?
The fan goes to 50% duty minimum when the A/C is turned on. However, I have found no practcal reason to hook up the A/C wire, or accessories wire since the unit runs perfectly fine without it. The sensor automatically adjusts for the temp. Try it without for a little bit and see how you like it.
