A 75 amp relay is a bit of an over kill. If you go to a stereo/alarm shop and find a good made in the USA or Germany 40-50 amp relay, you'd be set. You can also use a 40-50 amp switch. use a 30-35 amp fuse and good quality 12 (or 10 if you run the relay inside of the car) guage wire. This setup is a bit of an over kill, but very safe.
