Electric help. please?
  • Thread starter Thread starter canesstangnitro
  • Start date Start date May 28, 2007
C
canesstangnitro
109
Metairie, LA
May 28, 2007
  • May 28, 2007
My blinkers have never worked on my car. I went to the hazard switch. I looked and the wires were not connected to the connector. I connected all of the wires correctly to the connectors and pluged the connectors into the switch. Then, I changed all of the fuses that were blown and bought one of those round things to put on the fuse box for the turn signals. The light for the turn signal will turn on, but not blink. And it will only work with my headlights on. So I will turn my headlights on, put my turn signal on, and the light will come on but not flash. What would cause the turn signal to not flash but to come on and to only come on when I turn my headlights on. I know it sounds like some kind of short somewhere but where. Any help on this would really help. Also, 2 of the slots on the connector are worn so the wires are not staying in well. What is the easiest solution to this? they don't make connectors anymore. Should I look for a used one off a parts mustang. Would it even work. I hope I can get this fixed. Thank you for any help on this
C
canesstangnitro
109
Metairie, LA
May 28, 2007
  • May 28, 2007
90blacknight
136
May 28, 2007
  • May 28, 2007
The round thing you replaced in your fuse box should be the hazard flasher, not the turn signal flasher. If you need to replace the turn signal flasher, it can be located in various places, but usually around the back of the fuse box, behind the center console, or up behind the glove box on the left somewhere.
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2026
AeroCoupe
Electrical Turn Signal / Lights Issue
  • 86SilverFox
  • Jun 2, 2025
Fox 5.0 Mustang Tech Jun 3, 2025
General karthief
68 headlights hot working
  • Butchd88
  • Aug 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 3, 2026
Butchd88
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
