The only reasonable backup to drive by wire steering is an old fasion steering shaft. I cant see any other solution other than redundant solenoids, redundant steering wheel sensors and redundant actuators. By the time all that redundancy is built in, is the system better than the original and cost effective at the same time? No. How can it be? PS pumped steering has been pleasing customers for decades on existing high end cars...it's simple (reliable) and has an inherent backup in it's mechanical design, its smooth and quiet. I guess I'm getting old if I dont see the revolutionary breakthrough in drive by wire.
Fly by wire is different. At 10000 feet, if you suddenly cant turn, you still have a good shot at pulling the double o's and taking the silk elevator. Senders and actuators in that environment are much more efficient than their hydraulic and cable driven predecessors. This is what got people excited about it I guess....if it works in the stealth fighter/f-16, why not put it in my shiny new car?
On the ground...if you suddenly cant steer your car, you're probably testing out your airbags or hugging the inside of your windshield in a second or two.
BTW....the PS pump gives absolute negligable (1 hp or so) drag when going straight. Additionally, PS drag when turning is irrelevant since you never drag race in circles anyways and full throttle turning produces interesting results best left to other people. Keep the pump or go to a manual rack is weight is a concern.
