Electric Vacuum
geostang351
946
Danb., CT
I have power disc brakes from a Granada swap and a radical cam that doesn't produce enough vacuum at idle. As I slow down from say 50 mph, I stop very quickly. However, the last 10 mph are sometimes scary :eek: (feels like I'm going push the brake pedal support through the fire wall). I've been looking through the summit catalog but cannont find the electrical vacuum canisters for this problem. Under what catagory would this be listed?
Thanks
Try "electric vacuum pump" and another cheaper different option is a vacuum canister. The vacuum canister has a check valve in it to capture the highest vacuum your engine produces and stores it until you need it. I run one on my race car which idles at 5 in/mg but at the end of a run it produces about 18 in/mg which gives me a very easy pedal.
First thing I would do is get a $10 vacuum guage and determine if you really need to spend all that money.
When you are driving down the road, and you lift the throttle, your vacuum goes to the highest reading. I idle at 10-12", but deceleration on the road is around 20", which is more than enough for power brakes. If you apply the brakes while at 20" of vacuum, which is most the time, it will hold that vacuum. As a matter of fact, power boosters are designed to give one fully assisted stop should your car stall, which is zero vacuum.
I would make sure you really need to spend this money before diving in.
Well like first posted, as I complete the last 10 mph, you're saying I should have enough vacuum. If I do have enough, then what other problem may I be facing with my brakes? Any ideas?
If you are stopping OK from 50mph, but are having problems with the last ten MPH, that sounds really odd to me. The booster doesn't lose assist if working properly during one stop. I am not sure what to tell you, other than I think there may be some problem in the braking system, like a marginal booster, or something like that.
It just doesn't sound right. although I have never done the Granada swap, so I am hoping someone who has can weigh in.
