Electrical guru's come in here
Tinos87
100
West Springfield, MA
I have an 89LX which is being converted from a 4cyl. I put the harness from an 89 donor car in it and the computer I'm using is an A9S. I can't get the fuel pump to come on at all. The EEC relay is fine, I can here it click, and the fuel pump relay should be fine also because it worked with the 4cyl fine. I have 12v at the orange/lt blue wire under the driver seat but no power at the tan/lt green that comes from the computer terminal 22 when the key is in the on position. The car turns over fine and if I spray starting fluid in the intake it fires so I have spark. Even when I jump the fuel pump to run it still doesn't fire unless I spray strting fuild in it so the injectors aren't firing either. Is this a symptom of a bad computer? I tried to run the self test on the computer but it doesn't do a thing, no clicking, nothing?
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. A tire pressure gauge can also be used if you have one - look for 37-40 PSI. Beware of fire hazard when you do this.
No fuel pressure, possible failed items in order of their probability:
A.) Tripped inertia switch – press reset button on the inertia switch. The hatch cars hide it under the plastic trim covering the driver's side taillight. Use the voltmeter or test light to make sure you have power to both sides of the switch
B.) Fuel pump power relay – located under the driver’s seat in most stangs built before 92. On 92 and later model cars it is located below the Mass Air Flow meter.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Use a voltmeter to measure the voltage drop across them. There should be less than .75 volt drop across a fuse link.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
The electrical circuit for the fuel pump has two paths, a control path and a power path.
The control path consists of the inertia switch, the computer, and the fuel pump relay coil. It turns the fuel pump relay on or off under computer control. The switched power (red wire) from the ECC relay goes to the inertia switch (red/black wire) then from the inertia switch to the relay coil and then from the relay coil to the computer (tan/ Lt green wire). The computer provides the ground path to complete the circuit. This ground causes the relay coil to energize and close the contacts for the power path. Keep in mind that you can have voltage to all the right places, but the computer must provide a ground. If there is no ground, the relay will not close the power contacts.
The power path picks up from a fuse link near the starter relay. Fuse links are like fuses, except they are pieces of wire and are made right into the wiring harness. The feed wire from the fuse link (orange/ light blue wire) goes to the fuel pump relay contacts. When the contacts close because the relay energizes, the power flows through the contacts to the fuel pump (light pink/black wire). The fuel pump has a black wire that supplies the ground to complete the circuit.
Remember that the computer does not source power for any actuator or relay, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Now that you have the theory of how it works, it’s time to go digging.
Look for 12 volts at the Orange/Lt. Blue wire (power source for fuel pump relay). No voltage or low voltage, bad fuse link, bad wiring or connections. There is a mystery connector (one I haven’t found) under the dash somewhere, between the fuel pump relay and the fuse link.
Turn on the key and jumper the fuel pump test connector to ground as previously described. Look for 12 volts at the Light Pink/Black wire (relay controlled power for the fuel pump). No voltage there means that the relay has failed or there is a broken wire in the relay control circuit.
Check the Red/black wire, it should have 12 volts. No 12 volts there, either the inertia switch is open or has no power to it. Check both sides of the inertia switch: there should be power on the Red wire and Red/Black wire. Power on the Red wire and not on the Red/Black wire means the inertia switch is open.
The Tan/Lt Green wire provides a ground path for the relay power. With the test connector jumpered to ground, there should be less than .75 volts. Use a test lamp with one side connected to battery power and the other side to the Tan/Lt Green wire. The test light should glow brightly. No glow and you have a broken wire or bad connection between the test connector and the relay. To test the wiring from the computer, remove the passenger side kick panel and disconnect the computer connector. It has a 10 MM bolt that holds it in place. With the test lamp connected to power, jumper pin 22 to ground and the test lamp should glow. No glow and the wiring between the computer and the fuel pump relay is bad.
If and only if you have followed the test procedure to this point and still haven’t found the problem, the computer is suspect. :(
Make sure it is grounded by the starter realy. The ground has a round on the main harness and allot of time the part that plugs to the main harness and to the body comes up missing. Ran into this problem when I re wired my 86 with 89 harnesses. No fuel pump when the key was on. The plug to the body was missing, so I cut the plug off the main harness and added a loop , grounded it ,and the car fired up.
Ok, I checked some wires last night.
The orange/lt blue at the fuel pump relay has 12v. It does nothing when the car is in the on position. The EEC relay has 12v at the orange/bk wire and clicks when the key goes to the on position. No power at either wire at the inertia switch. 0v at the red wire coming from the EEC relay in the on position. Car still turns over fine but seems like no power at EEC?
With the conditions you describe, the ECC relay is supplying power to the fuel pump & computer.
Look for a broken wire or bad connection between the ECC relay and the red wire that goes to the inertia switch. With power off the circuit, measure resistance between one of the red wires on the injector harness and the red wire on the inertia switch. You should see less than 1 ohm.
See Tmoss's diagram that follows
Ok, I found a blue wire that was not connected to the starter relay that should have been, apparently this is the EEC power. Hooked it up and now I have power to the inertia switch and relays. Still no fuel pump turning on though. I jumped it by grounding the test port in the engine bay and it worked, car fired up and ran great, my first motor build! Tested the tan/lt green wire and it had .40 volts when jumpered so that seems ok. Must be the computer? I hooked up an old speed density computer to see and with the key on the pump primed fine. So I guess I'll be looking for a new computer. Thanks for all your help jrichker!
