Electrical Help
I need to put things back together now that the motor is in Im almost done.. can someone take pics of their cars or somehow get me all hooked up with all these wires? Where do these go?
I would be stoked if someone could take a pic of everything all done... thanks guys
sorry man i have no idea wut the mini starter is... I now the coil, the alt, the batt, and the starter but I dont know how they all come together and I had to replace some of the wires were corroded so I had to take them all arpart but they are still managable I just need to know where the gournds are and wut goes on that top on and where the thing in the bottom pic bolts to.
Standard wiring:
The aft 5/16" stud gets all the connections EXCEPT for the big wire that goes to the starter.
The front 5/16" stud gets the big wire that goes to the starter and nothing else.
The little 10-32 stud get the red push on connector
The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges. Any car that has a 3G alternator needs a 4 gauge ground wire running from the block to the chassis ground where the battery pigtail ground connects.
The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery. It is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
JerryDaugherty said:
thanks guys... another problem tackeled thanks to the forum.. this place is really sick... oh yea.. how many cables go to the starter?
Only one, the big cable that is the starter power feed.
