electrical issues....
  • Thread starter Thread starter srtthis
  • Start date Start date Jan 16, 2010
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Jan 16, 2010
  • Jan 16, 2010
put the wire harness back in the car last night after the cam swap...
now with the key out of the ignition and the battery hooked up. if i hit the brakes a relay over by the maf clicks. and i get no cranking... pretty sure i have all my grounds hooked up. anyone have any idea where to start with this issue? i HATE electrical issues....
srtthis
5,129
1,666
204
Maryland
Jan 16, 2010
  • Jan 16, 2010
the shift light also lights up when that relay clicks and my CEL light comes on
srtthis
5,129
1,666
204
Maryland
Jan 17, 2010
  • Jan 17, 2010
bump...
srtthis
5,129
1,666
204
Maryland
Jan 17, 2010
  • Jan 17, 2010
turned out to be the battery ground itself... the ground to the strut tower off the terminal
HISSIN50
34
129
Jan 17, 2010
  • Jan 17, 2010
I can't think of a battery ground that goes to the strut tower.
In any case, consider routing the grounding pathways similar to stock (though adding additional grounds is fine).
srtthis
5,129
1,666
204
Maryland
Jan 18, 2010
  • Jan 18, 2010
should have been stock... atleast it looked like a stock terminal on the end. its coming off soon anyway. the battery is going in the trunk and then im doing 2 2ga grounds off the motor.
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
