electrical issues....
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
put the wire harness back in the car last night after the cam swap...
now with the key out of the ignition and the battery hooked up. if i hit the brakes a relay over by the maf clicks. and i get no cranking... pretty sure i have all my grounds hooked up. anyone have any idea where to start with this issue? i HATE electrical issues....
turned out to be the battery ground itself... the ground to the strut tower off the terminal
I can't think of a battery ground that goes to the strut tower.
In any case, consider routing the grounding pathways similar to stock (though adding additional grounds is fine).
should have been stock... atleast it looked like a stock terminal on the end. its coming off soon anyway. the battery is going in the trunk and then im doing 2 2ga grounds off the motor.
