Electrical problem, need some help
  • Thread starter Thread starter 93LXstock
  • Start date Start date Aug 23, 2006
9
93LXstock
  • Aug 23, 2006
Went to fire up my sons 93LX the other day and nothing. Thought it might be the battery, but nothing on the jump. Thought it may have been the starter, bought a new one, but haven't got it in yet. I remembered I had replaced the ignition switch about to years ago when the car was acting the same. Pulled the steering column covers and the switch kinda fell apart when I removed it. Replaced the switch, but nothing. No power to the gages, idiot lights, windshield wipers, turn signals, stereo, or that familiar sound of the fuel pump humming. Checked all the fuses, and none of them were bad. Probably need to mention that there was some smoke that came from under the dash when my son attempting to start it so I could hear if the starter solinoid was trying to engage the starter. I have the dash apart to survey for burnt wires, but so far none have been found.
Any ideas as to where to look as I really don't want to take this in and have it looked at/repaired because as you all know that = BIG $$$$.
Thanks in advance for any insight.
5.0 con-vert
No soup for you, Joe Rogan!!!
Jun 7, 2005
244
Boca Raton, FL
Aug 23, 2006
  • Aug 23, 2006
Sounds like there is either a bad connection to the battery or a bad connection between the battery and solenoid. I would clean off all the terminals first and try again. Hopefully it is something simple like that. Its a good start though!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 23, 2006
  • Aug 23, 2006
Clean the battery terminals, clean the grounds. Don't miss the chassis power ground being pointed at in the next picture.
Picture courtesy timewarped1972
AutoZone wiring diagrams
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model Mustangs
9
93LXstock
  • Aug 23, 2006
Battery terminals are clean as well as connections, and the battery is charged. I'll look at the chassis ground. If this is ok, what would cause the gages, fuel pump, and others things listed above not to get any power if all the fuses are good? Man I hate electrical problems....
9
93LXstock
  • Aug 23, 2006
FYI guys, I think I found the problem as I was looking. There was a fusable link burnt through coming off the solinoid. Hopefully this will fix the problem.
Thanks. Will let you know how it turns out.
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2026
AeroCoupe
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Tuesday at 10:26 PM
AeroCoupe
