Electrical problem
  • Thread starter Thread starter Foxwolfe
  • Start date Start date Apr 13, 2007
F
Foxwolfe
28
Vallejo, CA
Apr 13, 2007
  • Apr 13, 2007
So I recently moved up to washington and had to smog my stang here, during the process I think the cig lighter plug in they use mighta shorted something out or blown a fuse cause since then I've been having problems.
First after I left the smog place I noticed my speedo was now dead, then a day or two later my auto meter tach starts moving around on it's own while I'm holding a constant speed or idling. Then finally it was like there was just a massive draw on the electrical system cause the car died and was losing power very very fast, I couldnt even have my hazard lights on while waiting for the tow.
I just wanted to see if anyone here had any ideas before I start checking stuff out on it tomorrow morning.
Aryan15
236
CA
Apr 13, 2007
  • Apr 13, 2007
Check the voltage at the battery. 12V while car is off, and 13-14V while its running. They might of reversed polarity, overcharged, wrong voltage, etc.
F
Foxwolfe
28
Vallejo, CA
Apr 13, 2007
  • Apr 13, 2007
Thats one of the problems, even with the car off it's like there is now a constant draw on the battery, it was down to 10v when I yanked it before heading inside, and it was only at 10-11v while the car was on.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 13, 2007
  • Apr 13, 2007
Limp down to the local auto parts store. Chain stores like AutoZone, Advance Auto Parts, etc will check your alternator and charging system for free.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
AutoZone wiring diagrams
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model Mustangs
  • Mindseye007
  • Aug 16, 2026
Mindseye007
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
