  • 1994 - 1995 Specific Tech
Electrical Problems
  • Thread starter Thread starter DarkProphet
  • Start date Start date Nov 4, 2006
DarkProphet
391
Quakertown, PA
Nov 4, 2006
  • Nov 4, 2006
Hey guys, my car is having some wierd electrical problems. The voltage, water temp, and oil pressure gauges will all jump around a little bit, and when I hit the brake I can notice the gauges moving up a bit (except for the volt meter which moves down a bit). Another wierd thing is that I noticed when turning right that the gauges act up, but when I turn to the left, they seem to go back to where they should. I checked under the dash for rubbing wires on the steering colum and wiring hitting the brake pedal but found none. Im about to take out the brake fuse and see if that fixes the problem. The brake fuse blew a few days ago so Im pretty sure that the problem lies in that area, but im not sure. It seems to be happening wether nor not I hit the brakes though, just worse when I do, and most of the brake circuit isnt hot until you hit the pedal. Where can I find the flasher module (also connected to the brake circuit) and "multi-function switch". Anyone have any ideas?
DarkProphet
391
Quakertown, PA
Nov 4, 2006
  • Nov 4, 2006
UPDATE:
I took out the fuse for the brake light and it made no difference. Im thinking now it might be that my alternator is starting to go. What are some signs of an alt dying? I tested the battery terminals at 14.83-14.85 volts with the car idling, and 12.93 or so with it off. Could a bad engine ground strap cause this too? I just put the motor in not too long ago and it could have loostened itself a bit.
blksn955.o
3,263
st.louis mo 314
Nov 4, 2006
  • Nov 4, 2006
I would start by checking all the grounds and the elec. connections for the guages on the motor. Getting the alt. tested wont do any harm either.
Methodical
1,192
11
59
Clinton, MD
Nov 4, 2006
  • Nov 4, 2006
DarkProphet said:
UPDATE:
If you are getting 14 volts with the car idling then the alternator is probably still good. I'd definately check the ground straps.
DarkProphet
391
Quakertown, PA
Nov 4, 2006
  • Nov 4, 2006
Fixed the problem. It was a ground. Thanks a lot guys!
A
Electrical electric mirror switch issue...
  • alchemist1
  • Apr 18, 2026
Fox 5.0 Mustang Tech Apr 19, 2026
2000xp8
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Sep 13, 2026
Mcmahst
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
U
Knowledge Sought
  • USMCE3ROFP
  • Dec 6, 2025
  • Other Auto Tech
Other Auto Tech Dec 6, 2025
USMCE3ROFP
U
D
Resolved 1985 GT brake pedal problems
  • DienstXIV
  • Jun 19, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2025
DienstXIV
D
