Electrical short
  • Thread starter Thread starter dception
  • Start date Start date Jun 11, 2005
D
dception
12
  • Jun 11, 2005
Hey
I have a 90 mustang convertible, and I shorted a wire somewhere. There was smoke coming from the steering column. The ignition key won't crank the starter, although the accessories come on. (Ie. radio, wipers, hazards, horn)The convertible top doesn't work, the directionals don't work, and also the heater blower. Any suggestions as to where to start looking for the short?
Thanks
HISSIN50
34
129
Jun 11, 2005
  • Jun 11, 2005
dception said:
I Any suggestions as to where to start looking for the short?
Thanks
Not knowing what you were working on, I would suggest the ignition switch. It was a recall item certain years and has been known to cause issues similar to what you describe.
Good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 11, 2005
  • Jun 11, 2005
Have fun finding all the damage...
Look closely at the wiring since when the switch overheats it can also damage the wiring connected to it. There have been several cases of that happening here on Stangnet reciently.
Ny Mustang Guy
322
Queens Nyc
Jun 11, 2005
  • Jun 11, 2005
you can use a test light to see if it is the ignition. I did that when My car wouldnt start and it had turned out my ignition switch went, which also had fried my wire...
D
dception
12
  • Jun 12, 2005
Thanks everyone! Will give it a try.
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
89 LX Electrical Troubles
  • fun331
  • Oct 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 27, 2025
fun331
P
Crank but no start BUT no power to gauges
  • project_88LX
  • Jan 13, 2025
Fox 5.0 Mustang Tech Jan 14, 2025
Mcmahst
P
Electrical 1988 GT Wrong Cluster- causing electrical issues?
  • pindude80
  • May 6, 2025
Fox 5.0 Mustang Tech May 6, 2025
pindude80
P
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
