  • 1994 - 1995 Specific Tech
Electrical Woe's Need Help!
  • Thread starter Thread starter VetteEater
  • Start date Start date Oct 24, 2005
V
VetteEater
85
EARTH
Oct 24, 2005
  • Oct 24, 2005
Hi,
I am having an issue with my '95 GT (details in siggy). My drivers seat does not work anymore and my tail light do not light up when I press the brake pedal. The parking lights in the rear work and the blinkers too but when I press the pedal nothing. Now immediatly you would think the brake switch (do not know the tech. name) was bad but the weird thing is the wing (cobra with led third brake light) still lights up when the pedal is pressed. I went to under the hood to check the fuses about the seat and the 30 amp fuse found here in the following picture (the green one on the bottom row sorry for a blurry picture) was blown:
I looked in the cover for what the desc. was for the fuse and it said "see owners manual" and unfortunatly I do not have one so could someone look it up for me please. I think it's the culprit for the seats seeing as they would need a fairly big fuse due to the higher voltage running through them so i got a 30 amp fuse and replaced it and right as I stuck it in it popped so something is shorting it out. Could the tail lights and the seats be tied together somehow? Anyone have insight that could help me out or possibly even experienced the same problem that has fixed it. I am currently right now trying t find the shorting issue and am getting ready to go out with a volt meter to test everything to see if I can find it. Thanks for the help everyone!
Josh
V
VetteEater
85
EARTH
Oct 24, 2005
  • Oct 24, 2005
Anyone?????
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Oct 24, 2005
  • Oct 24, 2005
Well .... test everything related .... that's the best I can tell you. As far as the new fuse popping .... try taking the main negative battery terminal off, then put a new 30A fuse in there, then put the negative terminal back on. If it pops then, you have a gremlin somewhere.
V
VetteEater
85
EARTH
Oct 24, 2005
  • Oct 24, 2005
Thanks for the input! I will try disconnecting the terminal and reconnecting to see if that cures the "short". I was going to test the wires in the back to see if they are even getting power.
The main thing that is really puzzling me is the l.e.d. on the wing is spliced into the main harness going to the tails and the L.E.D. lights up when the pedal is pressed but yet the main tail lights do not. Makes me thing something is wired improperly.
I don't know. I am going to take a good look at it tomorrow evening and get to the bottom of it.
N
Nagash01WS6
402
Deland, FL
Oct 25, 2005
  • Oct 25, 2005
That green 30 amp is for the seats / cigarette lighter. If your seats arent working, I bet the cig lighter isnt either.
As far as the tail lights, check the bulbs. You may have some filaments out.
Those are on different circuits.
HISSIN50
34
129
Oct 25, 2005
  • Oct 25, 2005
I would make sure change did not fall into the cig lighter receptacle.
V
VetteEater
85
EARTH
Oct 25, 2005
  • Oct 25, 2005
yup forgot to mention the lighter isn't working either. There isn't any change or really any debris as far as see. I could tell but I didn't really look the car over very well last night because I was really tired.
I am hoping it was just a big coincidence that both bulbs had the filiments burn but I highly doubt it. I am going to say it's wired wrong. I am going to pull the old multimeter out tonight and start testing wires to see what I can find.
Also, try to sort the seat issue as well. I thought that the 30 amp fuse was for the seats because usually power seats require a big fuse due to the motors and such and I was correct. Hopefully, thats nothing big either.
Thanks guys for all of the help I really appreciate it!
Josh
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
