  • SN95 4.6L Mustang Tech
Electrical WTF?!?!
  • Thread starter Thread starter mrshl13
  • Start date Start date May 12, 2005
M
mrshl13
57
  • May 12, 2005
As I started off to work this morning my '97 GT's ABS light came on and every time I started to let my clutch out the car tried to die. I limped back to the garage, shut down and then restarted. The car ran fine all the way to work. When I got to work and parked I shut down again and tried to restart just to test the waters. No power at all. Nothing. No warning bell, lights or radio.
I took the battery out and brought it to Sears. They tested it and said it was fine. I put it back in the car, tightened it down and it fired right up. I shut down and restarted at least 7 times, running accessories and the charge needle went right up to where it usually is every time I drive the car.
A little history:
When I first got the car in October of 2003 I had a grounding issue where the engine wouldn't accelerate and all the gauges and lights went haywire. The motor mounts had just been replaced and I had to tighten down the ground strap a little more.
Recently, my fuel gauge has been reading full sometimes on startup and then gradually going back down to where I know it should be.
Alternator? Ground strap again?
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
May 12, 2005
  • May 12, 2005
i would start by checking all the main grounds.
M
mrshl13
57
  • May 12, 2005
Where else besides the motor mount?
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
