eletrical problems, no power throught car
green
291
hey hows it going, have a qustion i need to ask as i am stumped on the problem. i have a 85 mustang gt, the other day the car would just click when turning over, so i put on a new selonoid swithch and that dident help, but now when i put on the key the power comes on but 2 seconds later all power goes away, if i turn the key off then on agian power wil come back on but then go right away, any ideas, thanks
where does that other end of the pigtail on the gound battery go? also the battery is not that old, just a few minuts ago i put the battery charger on the car and now this time i have real loud clicking coming from the selonoid switch (i just put that on this morning, its brand new) but with the battery charger on the car if i turn on my radio it dosent have enought power to play the radio, also the signal lights, when i turn them on it just blinks once and quits, there is just not enough power to run them, and that it with the charger on there. what would be causeing the problem, i mean what would stop the power from entering throught the car? would a bad starter cause this to happen? voltage regulator? i am not sure. thanks
ill tell you what the exact prob is is the battery terminals they are full of acid clean that and if that does not work then look that the negative and positive wires and sometimes they are full of acid and you may have to replace those or cut them till the wires look better and not full of acid
The main power ground is from engine block to battery: it is
the power ground for the starter & alternator.
The chassis ground and battery pigtail ground go to the bolt being pointed at in the following photo.
