Emergency please help
CooperCity
I bought an electric fan from a lincoln mark 8 I have a 93 Mustang GT. What electic fan controller should I use one that is going last for a long time.I heard these fans draw a lot of current on startup. Any help is greatly appreciated!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Also I live in So Fla do I need a thermostat?
Welcome to the forum.
Where's the emergency? You forgot to post about how your car left you stranded somewhere and you really needed help getting it home.
If you search, you will find more info than you know what to do with regarding the Mark 8 fan and how to best control it. And since time seems to be of the essence for you, that sounds like the way to go.
Good luck.
Lots of guys like the DCC fan controllers since they vary the speed of the fan and keep you from having the large current draw on start up. If you are going to do a switch and relay set up instead of the DCC then you need to upgrade the lalternator to the 3G style.
And yes you need a t stat even if you live in south FL.
