Emission pump by-pass???
  • Thread starter Thread starter PE1990
  • Start date Start date Apr 4, 2005
P
PE1990
14
Beirut, Lebanon
Apr 4, 2005
  • Apr 4, 2005
Hi!
I just disconnected the emission pump in front of the engine due to a bad bearing. Is it safe, mechanically, to operate the car without it. Remember hearing something from GM's V8 engines that the cylinder tops will overheat if the pump is by-passed?
We have no emission laws here, so that does not worry me too much.
Per.
CRASH7772
401
NH
Apr 4, 2005
  • Apr 4, 2005
PE1990 said:
Hi!
Per.
You should have no issues....and probably picked up a couple of ponies in the process that is I'm assuming that you are routing the belt not using the air pump? And if not you should....
FiveOCapri79
164
Lawton, Oklahoma
Apr 4, 2005
  • Apr 4, 2005
Been over 3 years since I've seen a smog pump on mine. Then again, there are no emissions to worry about here in Oklahoma.
04sleeper
2,674
14
89
Dallas, TX
Apr 4, 2005
  • Apr 4, 2005
If you still have on the cats then they could clog up over time due to not heating up enough from the extra air from the smog pump.
How long they last afterwards is a guess.
CRASH7772
401
NH
Apr 4, 2005
  • Apr 4, 2005
That is a possible.....I forgot about that since I have been bypassing the pump but running a Pro-chamber.
P
PE1990
14
Beirut, Lebanon
Apr 4, 2005
  • Apr 4, 2005
Thanks
Thanks a lot guys. That's all I needed to know.
Next will be to remove the pump all together.
Per.
T
TheUser
1,859
Springfield, MO
Apr 5, 2005
  • Apr 5, 2005
If you have catalytic converters on the car, I would recommend either fixing the smog pump or ditching the cats.
I think lack of smog pump can cause glowing cats.
P
PE1990
14
Beirut, Lebanon
Apr 5, 2005
  • Apr 5, 2005
James, I'll will check if the cat's are still there. If so they be gone in a hurry.
Thanks.
Per.
T
TheUser
1,859
Springfield, MO
Apr 6, 2005
  • Apr 6, 2005
lol I thought about this on the way to school this morning and my LX 5.0 doesn't have the air pipe from the smog pump to the cats and the cats don't glow and I don't have any drivability problems, so I'll take my statement back about the glowing cats - although I have heard of similar issues. I'm sure the cats definately need to be replaced though.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
