All tests were done at the same Test Facility using the same Test Equipment. Test Operators did very however.
Tested vehicle was an N/A 1987 Mustang Coupe. Mileage was 134,093 on first test, and 136,268 on final test (#4).
Other than the Catalytic Converter being removed, the car was in good running order for first test and all other tests. No Diagnostic codes were present.
<?***:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o
> </o
<o
> </o
Baseline Test
____­______Tested____Limit_____Result
HC Cruise___160______160______Pass
HC Idle_____709______220______FAIL!!!
CO Cruise___.51_______1.1______Pass
CO Idle_____.54_______1.2______Pass
Other than the lack of cats the car was in good running condition.
<o
> </o
<o
> </o
Re-Test #2
__________Tested____Limit_____Result
HC Cruise___142______160______Pass
HC Idle_____650______220______FAIL!!!
CO Idle_____.48_______1.2______Pass
Added New O2 Sensor, increased tire pressure to 52psi, disconnected fan to get engine hotter (good for reducing HC). Had run "Guaranteed to Pass" in previous tank (followed directions)
<o
> </o
<o
> </o
Re-Test #3
HC Cruise___173______160______FAIL!!!
HC Idle_____551______220______FAIL!!!
CO Cruise___.53_______1.1______Pass
CO Idle_____.61_______1.2______Pass
Replaced Factory N/A short block with Used Factory Turbo Block; this was due to a hole in Piston #4. Plugged the fan back in.
<o
> </o
<o
> </o
Re-Test #4
HC Cruise____44______160______Pass
HC Idle______61______220______Pass
CO Cruise___.06_______1.1______Pass
CO Idle_____.04_______1.2______Pass
A NEW Catalytic Converter from MagnaFlow had just been installed. At the time of the test, the cat had about 125 miles on it.
> </o
><o
> </o
>Baseline Test
<o
> </o
><o
> </o
>Re-Test #2
<o
> </o
><o
> </o
>Re-Test #3
<o
> </o
><o
> </o
>Re-Test #4
