Emissions woes continue, please help!!
  • Thread starter Thread starter kdog_x
  • Start date Start date Aug 2, 2004
1 of 2 Next Last
kdog_x
566
  • Aug 2, 2004
Well, I switched my O/R pipe for a MAC catted pipe, and I hooked the Air tube back up so I wouldn't kill the cats. But it looks like that wasn't enough to get me through emissions. Last time I went I got 3.9 for hydrocarbons, 0.8 is the limit. And 15.3 for CO, 15.0 is the limit. This time the hydrocarbons got better and the CO got worse. I've only got one more try, what should I do to this thing???
The emmisions reports can be viewed at the links below
http://www.wideopenwest.com/~kevinrush1/report2.JPG
http://www.wideopenwest.com/~kevinrush1/report4.JPG
mustangsquared
828
new bern nc
Aug 2, 2004
  • Aug 2, 2004
Smog pump working? New O2 sensors, tune up, lower FP? just a few ideas. The experts here should be able to help better.
kdog_x
566
  • Aug 2, 2004
Smog pump works, O2 sensors are about 2 yrs old, Cap and rotor are clean looking although maybe I'll replace them anyway, plugs are less than a year old as well as wires. Can you lower FP without an adjustable regulator?
kdog_x
566
  • Aug 2, 2004
I just went out and ran the codes, this is what I ended up with.
KOEO - 11
KOER - 41
Cylinder Balance Test - 99
Im trying to find that website with all the code listings now, I figured I'd post in case some one has it handy.
mustangsquared
828
new bern nc
Aug 2, 2004
  • Aug 2, 2004
Negative on the lower FP...also check the TPS sensor..if set over 1.0v can lead to a rich condition. Is the EGR working? Did you plug the EGR coolant lines? If so unplug them.
kdog_x
566
  • Aug 2, 2004
TPS sensor is set at 0.96V. Never bypassed the EGR coolant lines, if it wasn't working I think I would have got a code - right? I see that code 41 is (Right heated Exhaust Gas o2 sensor indicates system lean).
2 questions, by right do they mean passenger side, and would this make my car run rich? After re-reading the instructions I see I should have warmed up the car before running the test (said somethin about a HEGO sensor), I'm gonna go try it again and see if I get the same results.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 2, 2004
  • Aug 2, 2004
Code 41 or 91 - O2 indicates system lean. Look for a vacuum leak or failing O2 sensor.
The computer sees a lean mixture signal coming from the O2 sensors and tries to compensate by adding more fuel.
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. The computer pins are 29 (LH O2 with a dark green/pink wire) and 43 (RH O2 with a dark blue/pink wire). Use the ground next to the computer to ground the voltmeter.
The O2 sensor ground is in the wiring harness for the fuel injection wiring. I grounded mine to one of the intake manifold bolts
"When the mixture is lean, the exhaust gas has oxygen, about the same amount as the ambient air. So the sensor will generate less than .4 volt. Remember lean = less voltage.
" When the mixture is rich, there's less oxygen in the exhaust than in the ambient air , so voltage is generated between the two sides of the tip. The voltage is greater than .6 volt. Remember rich = more voltage.
Here's a tip: the newer the sensor, the more the voltage changes, swinging from as low as 0.1 volt to as much as 0.9 volt. As an oxygen sensor ages, the voltage changes get smaller and slower - the voltage change lags behind the change in exhaust gas oxygen.
Because the oxygen sensor generates its own voltage, never apply voltage and never measure resistance of the sensor circuit. To measure voltage signals, use an analog voltmeter with a high input impedance, at least 10 megohms. Remember, a digital voltmeter will average a changing voltage."
Charles O. Probst, Ford fuel Injection & Electronic Engine control
5.0guy
320
MI
Aug 2, 2004
  • Aug 2, 2004
http://www.corral.net/eec/
kdog_x
566
  • Aug 2, 2004
Del
kdog_x
566
#10
  • Aug 2, 2004
  • #10
Well I just checked the wires at the computer, both of them fluctuate alot. They both would start at about .2 or .3 and then would jump up to .7 or .8 then slowly drop a little and bounce back and forth between high and low. Is this what they're supposed to do?
kdog_x
566
#11
  • Aug 2, 2004
  • #11
Ok, I took all the plugs out and they had kind of a whiteish gray residue on them -- is that normal wear? I figured the best thing would be to go back to as close to stock parts as possible. So I threw on some 7mm wires, some motorcraft plugs, and a good cap and rotor (the one with the brass points on it). I'm gonna take it to carX tommorow and see what they say they can do, but I went to Midas today and they suggested I pull my exhaust off (LT's and all) and get the stocker 4 cat pipe back on. For a low one time fee of only $1000 of course. Ouch
Can anyone think of anything left I should do?
mustang88GT
186
Charlotte, North Carolina
Aug 2, 2004
#12
  • Aug 2, 2004
  • #12
when i failed i put my stock h back on... i dont think aftermarket x or h pipes with cats are not very effective hence the hp gain... i got a bassani X with 2 cats and i fail horribly but when i put the stocker back on passed easy... if u live near charlotte, NC u could borrow my stock h pipe
kdog_x
566
#13
  • Aug 2, 2004
  • #13
I wish I lived closer, I'm all the way up in Chicago. I'd have to go get some stock headers as well though, damn those smog cops
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 3, 2004
#14
  • Aug 3, 2004
  • #14
Sounds like they are working just like they are supposed to do.
kdog_x
566
#15
  • Aug 3, 2004
  • #15
I noticed that they turn off all accessories during the test, if accessories throw off the test then wouldn't my electric fan do the same thing?
kdog_x
566
#16
  • Aug 3, 2004
  • #16
Also, what do you think of this
http://www.passsmog.com/
or this
http://xcelplus.com/performance_restoration_kit_gas.htm
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 3, 2004
#17
  • Aug 3, 2004
  • #17
or this
http://www.passsmog.com seems to be the more interesting product. But then, I have no personal experience to back it up either.
kdog_x
566
#18
  • Aug 3, 2004
  • #18
I noticed I have a few broken vacuum lines, can anyone tell me if these are important and maybe where they go. One is in back of the smog pump on top of a round thing (valve maybe? sorry I cant be more descriptive). The other is on top of another valve at the intersection where it goes down to the cats or to the back of the heads.(see below). And there are two broken lines coming from the passenger side near the firewall (also see below). Any help would be appreciated.
http://www.wideopenwest.com/~kevinrush1/twotubes.jpg
http://www.wideopenwest.com/~kevinrush1/toptube.jpg
LAtely I've been starting the car and it will catch and then the RPMs will drop and it will die. Then I restart and everything is fine, it's done this like 3 times, could it be related?
shttygtstang
978
#19
  • Aug 3, 2004
  • #19
instead of spendin all this money have a shop rite it off .you bring your car to them they make a list(most of the time they realy dont do any thing)fix some stuff and sigh off saying they fixed your car and there no more they can do dmv will pass you your done
N
noslow5_0
422
dallas tx.
Aug 3, 2004
#20
  • Aug 3, 2004
  • #20
unless u capped off both ends there is ur code 41... vacuum leak!!
1 of 2 Next Last
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
A
Help with engine issues/emissions
  • Artyom
  • Apr 11, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 12, 2024
Mindseye007
Engine 1987 5.0 Sputtering & Jerking Please Help
  • Rauchbauer
  • Jan 15, 2023
7K
Fox 5.0 Mustang Tech Feb 1, 2023
AeroCoupe
K
Help P1151
  • Kowalski224
  • Jan 28, 2018
  • SN95 V6 Mustang Tech
7K
SN95 V6 Mustang Tech Jan 29, 2018
wmburns
J
Please Help With 77 Dodge Aspen With A9l, T5, 5.0l Swap. Starts Then Dies
  • Jalopychaser
  • Apr 26, 2017
3K
Fox 5.0 Mustang Tech Apr 27, 2017
a91what
