Engine Block Paint Job
Robertsl1978
In the near future I am going to be pulling the engine to do some spring cleaning and would like to make the engine block and compartment looking good. I have heard a good cleaner is oven cleaner and brush and bath. So my questions are if anybody had experience with using oven cleaner or what did you use to take the crap off and also what kind of paint should I use for the engine block? Thanks in advance.
For the engine compartment I would tuck those wires while the engine is out!! It's really easy to do, it's smoothing an engine bay that a ton of work and difficult. Also do any upgrades or maintenance to your power steering rack & bushings. Clean the compartment while the PS rack is removed. Or you can disregard that and move on to cleaning.
Cover all electrical connections and other things you don't want to get wet like vacuum lines etc... If you have a pressure washer you will want to use that or a garden hose will work ok. I like to first use warm water and dish soap and do some light general scrubbing and hose off. What's left is all the this engine oil and greasy areas which will mostly be in your K member and power steering area. You can use oven cleaner if you want or a good wax and grease remover and some brushes and get scrubbing.
For the engine i'd do the same (but no garden hose!). Clean it really well with a wax and grease remover and various brushes to get in all the tight areas. I've had good luck with Dupli-color engine enamel from the auto parts store.
Reactions: Robertsl1978
