Engine Bay Cleaning?
  • Thread starter Thread starter savegoodautonfg
  • Start date Start date May 3, 2006
savegoodautonfg
1,085
  • May 3, 2006
Good news! my long block is coming today and my mechanic is installing it over the weekend. complete long block swap. anyways..
When i get my car back i want to clean the engine bay really good cause since the car is a daily driver its dirty under the hood. What's the best way to go about doing this?
Supplies, Products, masking anything?
nazstang
204
Rhode Island
May 3, 2006
  • May 3, 2006
well just one question, can you clean it with the motor out? if so, that's the best scenario, you can literally get every crack and cranny cleaned alot easier like that. you could also do a little "touching up" with it out if you wanted to respray the engine bay.
if not, don't worry, you just need to watch out for a few things. before anything, cover up your dizzy real good, and the tps sensor aswell. if you have a open air filter in the bay, cover that also. now you can get to the cleaning. Simple green is a great degreaser that works great, and you'll need a few rags, a small-med. size brush or two, and your ready to go.
simply spray the degreaser on it, more heavily where it's more dirty, and let it sit a bit. then give it another pass with the degreaser and get your rag out, wet it a bit, and start to wash everywhere you can. once your done, use the brushes to get the grimiest stuff off, and then you can rinse it. give it a nice decently powerful rinse and then get some towels and dry off asmuch as you can. (i use my air compressor to blow off the water it the tough to get to spots). then take the covers off the dizzy and tps, and you can start the car. run it for a minute or 2 with the hood down, and then you can turn it off. the heat under the hood will steam out any other water that was under there. ALL DONE!
if you want now, you can even wax some spots in the bay(so dirt and dust doesn't stick so easy) and then use some silicone(tire shine) on the hoses, rubber lines, and other plastic bits under the hood. before you know it, you'll be ready for a car show
burnoutman
23
central PA.
May 3, 2006
  • May 3, 2006
I like castrol super clean spray it on right out of the bottle. don't spray it on the paint out of the engine bay. But plastic bags or tape over heater core nipples on the fire wall and on the ends of wires connector. Let this sit a few min. then go over as much of the area you can with a rag or what ever you have then hose it down if there is a few spots that is still not clean go back over them again.Give this a try i do this to my daily driver every spring to take of the winter crud. This is just my 2 $
Joe
ram360
2,162
Pennsylvania
May 3, 2006
  • May 3, 2006
pressure washer, and gunk engine degreaser
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
Engine What’s your preferred way to clean engine parts prior to assembly?
  • Xam Sirrah
  • Jun 6, 2025
Fox 5.0 Mustang Tech Jul 5, 2025
Methodical
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
