Engine Bucking-- IAC??
  • Thread starter Thread starter stang9215
  • Start date Start date Jan 28, 2008
stang9215
10
Northeast
Jan 28, 2008
  • Jan 28, 2008
I have a quick question about the IAC -- can a faulty IAC cause the car to buck when under partial throttle? My car bucks when cruising down the road (usually between 1600 -- 2100 rpms). The bucking goes away once I back off then reapply under a heavier throttle. Can this be attributed to a bad IAC? Any help would be appreciated
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 28, 2008
  • Jan 28, 2008
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
stang9215
10
Northeast
Jan 29, 2008
  • Jan 29, 2008
Thanks jrichker, I have a friend who has the scanner so I'll give that a try.
87foxstang
Cromwell, CT
Jan 29, 2008
  • Jan 29, 2008
Yea run the codes. But that could also be the TPS
The O.G.
145
witch city,mass
Jan 29, 2008
  • Jan 29, 2008
mine bucked from vaccum leak
stang9215
10
Northeast
Jan 30, 2008
  • Jan 30, 2008
A vacuum leak is another possibility, though all my vacuum lines were checked. My O2 sensors are pretty old (haven't been replaced since 1997), so replacing them may be a simple fix. The car is not a daily driver, but the O2 sensors probably have 30-40k miles on them.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
C
Engine Code 13 and high idle
  • CmdrDerp
  • Dec 14, 2024
Fox 5.0 Mustang Tech Dec 21, 2024
manicmechanic007
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
