Engine code...
  • Thread starter Thread starter Twistedimage
  • Start date Start date May 4, 2009
T
Twistedimage
15
St. Louis
May 4, 2009
  • May 4, 2009
Ok so sometimes when im driving the check engine light comes on for maybe 15 seconds for up to 2 mins than goes off, how can i check the code if it never stays on or does it during idle? btw i have a 89 mustang lx.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 4, 2009
  • May 4, 2009
Dumping The computer Diagnostic codes on 86-95 Mustangs
Revised 24-Apr-2009 to add warning to turn off A/C and place transmission in Neutral and dumping Engine Running codes.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
T
Twistedimage
15
St. Louis
May 8, 2009
  • May 8, 2009
ok i dont understand what wire to use from the sti to the connecter...? any help thanks !
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 8, 2009
  • May 8, 2009
Then I suggest you enlist the aide of a friend. I can't make it any simplier...
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
