Code 34 EGR voltage above closed limit - Failed sensor, carbon between EGR pintle valve and seat holding the valve off its seat. Remove the EGR valve and clean it with carbon remover. Prior to re-installing see if you can blow air through the EGR valve by mouth. If you can, replace the EGR valve ($85-$95).
