SN95 Engine Coolant Temp Sensor. In Hose Or Intake?
  • Thread starter Thread starter 90lxwhite
  • Start date Start date Oct 2, 2014
90lxwhite
I'm kind of a She-Man
5 Year Member
Aug 25, 2011
3,310
374
134
Between the Red and Rio
Oct 2, 2014
  • Oct 2, 2014
I have obd code 118, engine coolant temp sensor above max voltage. The chilton's manual says the ect is in the lower intake. Upon "doing a search" I read that the sensor that sends info to the computer is in a heater hose and the one in the intake just sends a signal to the temp gauge. Is this correct? If so whats the sensor in the hose? When I look up ect to purchase it seems they are selling the one in the manifold. Here are some examples. Are they even the same part? One has an electrical connector and the other doesnt appear to have one. Which do I want?
http://m.autopartswarehouse.com/sku...44&c2cid=47ca44b0-1a4c-4382-804c-e550e60dbb6c
http://m.americanmuscle.com/ford-temp-sensor-8395.html
coupestang2
108
132
53
Cornelius NC
Oct 2, 2014
  • Oct 2, 2014
Engine coolant sensor, should be on the hardline. Air Charge sensor is located on the intake
Mustang5L5
Mod Dude
Feb 18, 2001
43,390
18,133
224
Massachusetts
Oct 2, 2014
  • Oct 2, 2014
You are correct. The small 1-wire sender at the front driver's side of the intake is for the coolant temp gauge.
The engine coolant temp sensor used by the computer is located in the heater pipe that runs along the passenger side of the intake. The sensor is standing straight up just in front of the intake neck.
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Oct 2, 2014
  • Oct 2, 2014
Thanks
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Oct 2, 2014
  • Oct 2, 2014
In the hardline for the heater core, except on an SN it faces forward, not straight up.
Kurt
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Oct 3, 2014
  • Oct 3, 2014
both of mine sit in the intake but... what they are saying is correct if you still have heat
casey.poe.735
Boaz, Alabama
Oct 8, 2014
  • Oct 8, 2014
I look at the image in your link that is the temperature sensor that tells the gauge the temperature of the coolent. Now I am trying to think that it is a coolent temp sensor it is a two wire it can cause the car to run ruff and lose power.now the air charge sensor it is located in the air cleaner box I have not seen that many go out
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
A
1991 5.0 with HCI - started car, running for a few minutes, started pushing coolant into the overflow tank and then puking out from there. I'm lost
  • AmericanMuscle4.6GT
  • Oct 16, 2022
4K
Fox 5.0 Mustang Tech Nov 30, 2022
CAMTWO1070
Coolant Temp Sensor Help
  • 93CalypsoConvert
  • Jan 6, 2021
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 6, 2021
90sickfox
