Hi,
Does this occur warm or cold (open or closed loop) or driving normally at any RPM, or moreso when you’re pushing the car under a load, e.g. right foot planted?
Seem like a single cylinder is dropping out for a quick second or does the entire ignition seem to stumble entirely?
TFI OEM or aftermarket?
Take a peek into your Dizzy for moisture & blast it clean, inspect the Cap and Rotor carefully for cracks.
KOEO Voltage to the coil, then KOER.
Aside from what pulling EEC codes may tell you, vague responses are
Please include further detail, it’ll help eliminate vague responses.
How frequently does this occur, did it occur once, then more frequent over time? Or just one day it just began and remains the same?
A simple start is looming up your plug wires, reasonably separating from each other and any grounds.
Fire it up at night and look for stray arc’s.
Check your most recent ignition connections and those around them.
As you may realize, MSD and other aftermarket ignition components sometimes don’t bode so well and are many times the source of issues like yours. Can you bypass the MSD box temporarily?
Pull your plugs and see what they tell you.
Blast your MAF with CRC.
Fuel pressure at the rail
Grounds all solid.
Good luck!
John
