OK, heres the story. I have an 86 SVO Mustang with a 87 5.0 motor installed. This car has been sitting in retirement for about two years and I am ready to get this car back on street duty. The problem is, before I put the car up, it would run hot. The real problem is it would only run hot when running on the highway, not sitting at idle or cruising around town!!! When on the highway the temperature gauge would come up and the engine would ping. I have never heard of a car only running hot on the highway. The engine sounds and runs fine otherwise. What is wrong????
Let me give you some more information. Before the trouble started I changed the water pump, put on 1.7 roller rockers and I changed the timing chain. The car did not run hot before these changes. The car has a relatively new 3 core Modine radiator, 180 deg. high flow themstat, stock clutch fan and shroud.
If I remember correctly I tried playing with thermostats and that did not help. I just took the water pump off this weekend to see if they gave me the wrong water pump but it matches my old water pump (checked the impeller).
My next guess is that the lower radiator hose is collapsing?? I don't know.
Please help me this 5.0 get back on its feet
Gears
Gears
