Engine Failsafe Mode!
  • Thread starter Thread starter Stanggang99
  • Start date Start date Apr 24, 2018
Stanggang99
Monroe Wi
Apr 24, 2018
  • Apr 24, 2018
Hi new to the forums, I just bought an 05 Mustang GT with about 85k miles on it. After owning it for a month I decided to take a look at the air filter (dirty) and decided while at Walmart just grab a cheap one to get some cleaner air into the engine before I get a cold air intake(hopefully coming soon). However since I have replaced the air filter the engine has killed once at idle yesterday and today after it had sat for awhile I started it up, it revved high and kept fluctuating. I started to drive and about 10 secs after it kicked into Engine Failsafe Mode. I turned a few corners, shut it off for 5mins, took the air filter out and started it again. Ran fine back to my storage unit. Could the cheap filter be causing the problem? Need help asap as I would like to drive the car! Thank you!
Stanggang99
Monroe Wi
Apr 24, 2018
  • Apr 24, 2018
I should also say that this problem did not happen for the last month while owning the car before replacing the filter. Thanks!
Admin Dude
Jan 4, 1985
43,201
21,377
234
Box behind Walmart
Apr 25, 2018
  • Apr 25, 2018
Pull codes. You can get a cheap OBD2 reader from Walmart.
Stanggang99
Monroe Wi
Apr 25, 2018
  • Apr 25, 2018
No check engine light was on but my plan was to do that tonight. Any ideas on what it could be?
SpartaPerformance
2,517
61
89
Long Island NY
May 1, 2018
  • May 1, 2018
Something isn't right, either the new filter is placed in correctly or the airbox isn't sealed right and your letting in air from someplace
Reactions: I only know what I know
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
07 v6 4.0 wiring issue .In desperate need of help.
  • Staycstang
  • Sep 19, 2025
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Sep 19, 2025
D
SN95 V6 1994 occasional rpm surge while driving---where should I start?
  • DPP
  • Aug 30, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 5, 2026
DPP
D
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
