engine fan
Sorry. I was looking at the Wiring diagrams for the 1999-2004. The older Mustangs have a single speed fan.
For the 1999-2004, the V6 fan has a LOW speed only. The V8 has a two speed fan. The v8 fan uses all 3 wires. Low speed is RD/OR. High speed is OR/LB. Ground is BK.
The V6 fan has RD/OR and BK only.
The V6 fan will work fine when the PCM calls for low speed. When the PCM calls for HIGH speed, the fan will not run (unless rewired). Expect to overheat on a hot day stuck in traffic.
My 96 is dual speed...new fan is about $160. I got mine from Carquest and has a lifetime warranty.
It is a dual speed on your car. You need to run the low speed high speed test to see if it is working correctly.
