ENGINE GOOO RRUUUU'S
  • Thread starter Thread starter DMAN302
  • Start date Start date Apr 14, 2004
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Apr 14, 2004
  • Apr 14, 2004
Going in for the rebuild on my 88, so here's the deal...I need some advice on my chosen combo. Ok first I am staying SD so please omit the mass air comments cause I have already decided to stay SD. Now for the goodies- complete rebuild short block to original spec, with Crower cam #15511 and windsor Jr heads with all new hardware and springs, 1.6 RR's and 70mm TB with Edlebrock RPM intake (upper and lower) with Mac LT's and O/R h with U/D pullies. Well that's going to be the set up I picked so give me some input if you can as to who else has this and if so what kind of HP/TQ will be there for me.
Thanks guys,
Derek
Mike86Stang
Advanced Member
Apr 11, 2000
10,296
Red Lion, PA
Apr 14, 2004
  • Apr 14, 2004
Don't know anyone with that combo but once you get it to run right I'd say about 270-280 rwhp ...tq should be around 300-330 educated guess
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Apr 14, 2004
  • Apr 14, 2004
Really hoping no tuning will be necessary the Cam was picked just for the speed density set up it is made to fall in the usable range with speed density and I know the heads will not cause any real problems, so I'm woundering with stock 19's flowing the fuel at 39psi off vac, do you see any reason why I might run too lean?.Injectors can flow far above my required volume in the 300HP or less range, would there be any reason to need a chip?? I don't think the combo is all that agressive in terms of other H/C/I combo's out there, I'm looking for moderate good power gains while maintaining reliability.
Mike86Stang
Advanced Member
Apr 11, 2000
10,296
Red Lion, PA
Apr 15, 2004
  • Apr 15, 2004
Tunning by way of a chip or what ever probably not really needed. You will need to do some tweaking with the FP/TPS/ possible a MAP vacuum restrictor... but beyond that it should run/drive fine.
A
1991 5.0 - fires up every time, idles perfectly, but once it’s warm it won’t idle for more than 15 seconds
  • AmericanMuscle4.6GT
  • Jul 27, 2021
  • 2 3
9K
Fox 5.0 Mustang Tech May 21, 2022
Mindseye007
C
  • Locked
91 LX Hatchback LOADS of extras!!
  • claytucc3
  • Jul 21, 2010
3K
Fox Body Mustangs For Sale (1979-93) Aug 23, 2010
claytucc3
C
R
Project Grocery Gitter
  • RatStang
  • Oct 3, 2010
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 4, 2010
RatStang
R
T
Yet Another How's My 331 Combo Thread
  • thekid760
  • May 17, 2008
Fox 5.0 Mustang Tech May 19, 2008
5spd GT
C
new member 1st post w/video
  • CALYPSONOTCH
  • Mar 22, 2009
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2009
MAC'n89Blckstng
