  • 1994 - 1995 Specific Tech
Engine grounds...
  • Thread starter Thread starter The Green GT
  • Start date Start date Mar 30, 2006
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Mar 30, 2006
  • Mar 30, 2006
Where are all the main grounds for the car?
95Vert
1,785
North Mexico (deep south Texas)
Mar 30, 2006
  • Mar 30, 2006
I think there's one on the driver's side by the motor mount on the block. I'm not sure tho.
The Green GT
1,269
Louisiana
Mar 30, 2006
  • Mar 30, 2006
Where does it connect to the cars body?
95Vert
1,785
Mar 30, 2006
  • Mar 30, 2006
Nope, to the engine block.
The Green GT
1,269
Louisiana
Mar 30, 2006
  • Mar 30, 2006
I thought it went from the block to the body to ground them together?
69clark
731
Ravena, NY
Mar 31, 2006
  • Mar 31, 2006
Thats what I thought.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Mar 31, 2006
  • Mar 31, 2006
There is another that uses one of the oil pan bolts (the stud that goes through the oil pan and into the timing cover.
V
venom97
258
Illinois
Mar 31, 2006
  • Mar 31, 2006
it actually connects to the motor mount bolt and goes to the body. the bolt it connects to is located upside down or on the bottom of the rail. kind of by where the sway bar goes. its hard to explain but if your under the car looking up thats where it bolts to.
95strokerPSU
986
Sacramento from Philly
Mar 31, 2006
  • Mar 31, 2006
Isn't there a ground on the radiator support right where the hood prop rod pivots?
V
venom97
258
Illinois
Mar 31, 2006
#10
  • Mar 31, 2006
  • #10
i know there is one one the drivers side front,close to where the rad support is.
FlyBy763
439
Palm Bay, FL
Mar 31, 2006
#11
  • Mar 31, 2006
  • #11
Yeah, be careful of that one by the oil filter...mine was rubbing on my oil filter and grounding on the filter. My car wouldnt start....took me about a week to figure out thats what it was....
Starman
78
#12
  • Apr 1, 2006
  • #12
main ground is on the drivers side front motor mount stud and goes over to the bottom edge of the frame rail using a self taping sheetmetal type screw (green).
There is also a ground for the engine harness that attaches to a stud on the side of the timing chain cover just in front of the oil pressure sender.
Zero Signal
2,633
Tucson, AZ
Apr 1, 2006
#13
  • Apr 1, 2006
  • #13
Was just gonna say that
R
Help finding where this ground goes on the L head
  • RubberDuckUsb
  • Sep 11, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Sep 11, 2026
RubberDuckUsb
R
F
Ground wire
  • fox1990
  • Feb 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 12, 2026
manicmechanic007
A
2005 Ground Locations
  • Anderz
  • May 1, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 1, 2026
Anderz
A
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
D
Negative Grounds for 2008 4.0L
  • deadbeat
  • May 13, 2026
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech May 13, 2026
deadbeat
D
