Where does it connect to the cars body?95Vert said:I think there's one on the driver's side by the motor mount on the block. I'm not sure tho.
I thought it went from the block to the body to ground them together?95Vert said:Nope, to the engine block.
The Green GT said:Where does it connect to the cars body?
main ground is on the drivers side front motor mount stud and goes over to the bottom edge of the frame rail using a self taping sheetmetal type screw (green).
There is also a ground for the engine harness that attaches to a stud on the side of the timing chain cover just in front of the oil pressure sender.
