engine idle is rough
  • Thread starter Thread starter '88 5FOX
  • Start date Start date Aug 31, 2010
'88 5FOX
29
Seagrove NC
Aug 31, 2010
  • Aug 31, 2010
I am new to this site and think I am in the right place to be asking questions.
I have a 88 fox that I converted the trans to a 5 speed, and slid another motor down in. Last week it was running fine. I had two injectors leaking so I replaced all of them, now I have no leaks. But I installed 24lb injectors in on a speed density system. Found out that wouldn't work and installed a mass air system on it hoping to fix it. It didn't and now it will run but idle's like there is a vacuum loose although I have thourghly checked all of them. It throws black smoke when I step on it and from what idle I do have if I step on it it will studder out at around 3500 and kicks black smoke everywhere. When I unplug the mass air it doesn't affect the idle one bit. I have even checked it with a known good sensor and the tps. Timing is also set at factory specs. Neither fixed the problem. I don't want to blow my spark plugs out while driving. Can anyone give me a hand on what I should try next.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 31, 2010
  • Aug 31, 2010
You posted a TECH question in Talk. This limits your chances of getting some really good advice, since most guys aren't looking for Tech stuff in the Talk forum. PM one of the Mods (85ragtop, Killercanary, Mustang5L5, Celeb, FrankenStang, FastDriver ) and ask them to move it to 5.0 Tech. You’ll get a lot more responses to your question.
Having said that, here’s some help…
When you use lager injectors you need a aftermarket MAF calibrated to match the injectors or a custom computer tune. Until you fix that problem, you are going to have performance/driveablity issues.
Stock injectors are 19 LB orange or tan tops. You don't need 24 LB injectors on a stock engine,
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Aug 31, 2010
  • Aug 31, 2010
Everything he said.
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,114
224
Massachusetts
Aug 31, 2010
  • Aug 31, 2010
Moved to tech.
Get a calibrated maf on there and then dump the check engine codes
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
