Engine Just Died?
  • Thread starter Thread starter dcurtis
  • Start date Start date Oct 6, 2007
dcurtis
688
Oct 6, 2007
  • Oct 6, 2007
Ok, so a few weeks ago I was driving home like normal and my stangs engine just up and dies on me, I crank it about 3 or 4 times and stop thinking there is something wrong but I couldn't find anything wrong, so I decided to try to start it again and it fires right up Tonight, or just now I might say, I was driving like normal, and it just up and died on me again, so I rolled to a stop, put it in park and turn the key off and then to the on position to see if I could hear the fuel pump and I could so I cranked it 2 or 3 times and nothing, I let it sit for maybe a minute tops and try again and it fired right up, just like last time, so my question is, what the heck is wrong????????????, also it has only happened twice and I don't want it to make this a habit. Thanks for any input.
cenok is family
1,409
69
79
Norman, Ok
Oct 6, 2007
  • Oct 6, 2007
my car did that once about a week ago. i realized what it was instantly....i forgot to re-tighten the nut on my solonoid after i pulled my old alternator power wire out. just something to check/think about. not necessarily the nut backing out but the solonoid itself
Fast63
717
  • Oct 6, 2007
I had that happen to me where it would die, but it would fire right up again, but die right away and it was the ignition switch. Since yours does not even fire while cranking, you could probably rule that out.
F
fastest stock 87 gt
186
florida
Oct 7, 2007
  • Oct 7, 2007
TFI module
dcurtis
688
Oct 7, 2007
  • Oct 7, 2007
Sorry, I should of stated that better, but when Mine died, when I would crank it, it would fire for just a second and die instantly after, but, if I wait a minute or so it would fire right up, so it does fire while cranking, it just dies as soon as it does fire, where is the ignition switch, and where is the TFI module? Hoping to fix this soon because I don't want it to die somewhere embarassing, like the middle of the street And how much do these things cost?
Fast63
717
  • Oct 7, 2007
The ignition switch is right in the steering column where you put your key in. It costs 20-25 dollars and is fairly simple to replace. When that happens, do you lose power at all when the key is in the "on" position? Will it cut in and out if you move the key back and forth in the on position? Does the tumbler assembly that you put your key into feel kind of loose?
dcurtis
688
Oct 7, 2007
  • Oct 7, 2007
No, mine feels fine, I haven't noticed it losing power at all when it happens either, it just dies, it's very annoying though, what all should I check , I know it's only happened 2 times but I don't want it to happen ever againg so I will buy and replace anything in question.
F
fastest stock 87 gt
186
florida
Oct 7, 2007
  • Oct 7, 2007
The tfi module is the gray thing on the side of the distributor.
check this out......http://www.coolcats.net/tech/troubleshooting/tfi.html
dcurtis
688
Oct 7, 2007
  • Oct 7, 2007
I am just going to go down to auto zone and buy a new ignition switch, tfi and pip, and hopefully one of them are the problem, and if not, atleast I won't have to worry about them again for a while, someone said it may be the fuel pump, could it be the fuel pump, my brother had a blazer that would do pretty much the same thing just out of the blue and it was the fuel pump going bad?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 7, 2007
#10
  • Oct 7, 2007
  • #10
When you get tired of throwing parts at the probem, try this...
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
Revised 26-Aug-2007 to add missing secondary ground on back of the engine.
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. See paragraph 5A - a noid light will tell if the pip is working by flashing when the engine is cranking.
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire with the switch in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position, then the fuse link is blown.
H.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
J.) Computer
I.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) A noid light available from any auto parts store, is one way to test the injector wiring.
The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.99 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
dcurtis
688
Jan 16, 2008
#11
  • Jan 16, 2008
  • #11
Ok, first off, Jrichker, I will never get tired of throwing money at my car, it can only make it better, or atleast make it have enen more new parts on it, any how I just went out a while back and bought a new distributor, one with out the TFI module on it, I put in the new dizzy and my old tfi and cap and rotor and the car has not up and died at all since. Just letting you all know incase this happens to you.
golfvman
Alberta
Jan 17, 2008
#12
  • Jan 17, 2008
  • #12
I was going to offer my 2 cents, because I had this exact problem with mine and it ended up that the distributor was pooched.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
