  • SN95 4.6L Mustang Tech
Engine knocking.. Help please !!!!!!
  • Thread starter Thread starter rcapilli
  • Start date Start date Dec 31, 2005
1 of 2 Next Last
R
rcapilli
32
  • Dec 31, 2005
I have a 2001 Cobra with 46,000mi on it. There are no mods to the car. I noticed a knocking noice the other day and narrowed it down to some details. This behavior is a little different than some I have read, so read with a keen eye please.
Then I first start my engine it is great. No knocking at all. After about 3 minutes of driving I can hear a faint knocking. 10 minutes of driving I can really hear it. When I pop the hood and rev the engine I can hear the knocking from the back of the motor near the firewall. While driving you hear the knocking when you let up off the pedal just a little bit as though to give it gas but you are not really putting much power into the car. I took it to the dealership and they did a oil flush. They said some sludge came out of the car but the knocking still remained. Cylinders 1 and 6 are said to be having the problem. The dealerships solution was a new engine. I don't think I am sold on that suggestion quite yet. I am looking for some suggestions and wondering if some of the weird products like Z-Max or anything like that would help. What could this be and am I doomed here? I really don't want to refinance my house for $7,000 worth of a new car engine. Ya know?
Lastly... if I HAVE to spend $7000 for a new engine what should I get? I need one that is already built, buy and put in. Might as well go for something Bad Ass, right?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Dec 31, 2005
  • Dec 31, 2005
A new engine? That seems a little extreme... I would take it to another dealership and get it diagnosed for real.
Dan_Soprano
7,410
54
129
Jacksonville, FL
Dec 31, 2005
  • Dec 31, 2005
R
rcapilli
32
  • Dec 31, 2005
I agree, That is what I am going to do. May be a 3rd oppinion also. Any other ideas/suggestions?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Dec 31, 2005
  • Dec 31, 2005
Well, I do not know much about the problem you are describing. It could be a number of things. I believe that there is a TSB about Cobra heads "ticking" and a cold start rattle from the engine. You might try using SeaFoam on it, but that is just grasping at straws really...
How well has the car been maintained? Has it had regular oil changes and such?
CanadaStang
2,093
Mb
Dec 31, 2005
  • Dec 31, 2005
It's pretty tough to diagnose without actually being able to hear it, but I'm with the others on taking it somewhere else.
CanadaStang
2,093
Mb
Dec 31, 2005
  • Dec 31, 2005
A few times now I've had customers complain of a knocking noise and I've found a piece of the tin foil from an oil container sticking on top of the lifter.
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 31, 2005
  • Dec 31, 2005
spun a bearing.
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 31, 2005
  • Dec 31, 2005
stop driving the car or you'll lose your whole engine
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Dec 31, 2005
#10
  • Dec 31, 2005
  • #10
damn tom your a bad ass
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Dec 31, 2005
#11
  • Dec 31, 2005
  • #11
tomustang said:
spun a bearing.
Ahhhhh memories, huh Tom?
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Dec 31, 2005
#12
  • Dec 31, 2005
  • #12
if he spun a bearing it he needs a rebuild anyways.. but what he is describing could be a lot of other things too.. first check your plugs... loose plugs where the threads start too strip out can cause a ticking when the engine warms up.. if thats the case remove the plugs.. put some anti seize on them and tourqe them down and recheck every few thousand miles.. without hearing the noise it is impossible too tell whats going on..
BTW there was sludge in the motor? how often do you change your oil.. change your oil often in any performance application.. the more the better.. i dont care what these 20k oil change people on here say.. when you go long without oil changes you get sludge and bearing wear..
hopefully it's just plugs loose or somthing other than a bearing.. if it is i would either build up somthing good or try too get a used motor.. stay away from the ford dealer RMP crap.. those motors suck..
hotmustang331
2,967
Bastrop,TX
Jan 1, 2006
#13
  • Jan 1, 2006
  • #13
Well, it is possable that your knock sensor went out...and your building carbon. that may be causing detonation. How often is the car nailed? If its just putted around, that may be it. Try some seafoam first, along with checking your plugs. And I WOULD NOT put lock tight on the threads since the heads are aluminum...if anything, we put antiseize. If you do, I doubt you will ever get them back out....especially the red stuff lol.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jan 1, 2006
#14
  • Jan 1, 2006
  • #14
No one said ANYTHING about putting lock tite on anything except you
hotmustang331
2,967
Bastrop,TX
Jan 1, 2006
#15
  • Jan 1, 2006
  • #15
Opps...missread above post. thought he said "locktight" for some reason...hmm
And dont get smart Mr K&N filter boy. LOL
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jan 1, 2006
#16
  • Jan 1, 2006
  • #16
Well, it is an important point because there was a rather heated debate on the subject of lock tite on plug threads... It is not recommended
Ford's fix for spark plug blowout is using AGSF series plugs instead of AWSF series.
Also, checking the plug torque a while after installing new plugs will help prevent spark plug blowout.
F
FalconGuy016
437
Northern VA
Jan 1, 2006
#17
  • Jan 1, 2006
  • #17
MMmmm, $7000 ...
http://modularpowerhouse.com/produc...id=54&osCsid=2b42c1dbb74af0034f94fbdca1c69872
http://www.kennebell.net/superchargers/ford/gt96-03_2v/gt96-04.htm
Sure it's 2v but... a badass one.
R
Red2000GT
2,450
Regina,Sask.Canada
Jan 1, 2006
#18
  • Jan 1, 2006
  • #18
Mechanical damage dosn't come and go depending on the temperature of the motor. I'd check 2 real easy things(things I can talk about from personal experience). 1)Check to see if something is hitting the hood of the car when running. My upper intake hits very slightly on my hood from time to time and from inside the car it sounded exactly like a bad bearing.
2) check everything around the lower half of the motor. If a motor mount has worn out the exhaust may hit on the steering shaft and cause a very similar noise,but the main thing is to look for anything that could be hitting between the engine and the car itself.
I'm not saying that it's definately not a spun bearing but always check the easy stuff first before getting too excited.
Mike97gt
it doe snot
10,633
Jan 1, 2006
#19
  • Jan 1, 2006
  • #19
a long time ago ford had us locktite some lighting plugs before they came out with the "fixed" plug.. well anyways i dont want too start that debate again..
you could put locktite on them.. and if you did they will never loosen up again.. BUT i tried this and noticed when i got them out the threads were a little damaged and needed too be chased too get another plug back in.. so instead i would use antiseize tourqe them down right and recheck often.. this was done on a 5.4 supercharged truck
we tried this on a couple of different 5.4 supercharged trucks.. and in a extreme situation i would still use this.. ( heavy boost, idiot owner that would never check the plugs) but for your average mustang just check them every so often..
back in that debate there was a few people that said the locktite would cause them too back out and that is just retarded... the use of a medium strenth high heat locktite would not cause that..
Mike97gt
it doe snot
10,633
Jan 1, 2006
#20
  • Jan 1, 2006
  • #20
lets not rehash a 6 month old heated debate... the locktite thing is dead leave it dead.. we did use it on a few trucks and we got the plugs out.. had too chase the holes too get plugs back in LOL but i got them out.. agian
I DO NOT RECOMEND THE USE OF LOCKTITE BY ANY MEMBER OF THIS BOARD.. but i still will continue too play with it and test it on my own.. if i ruin a cylinder head it's not the end of the world for me..
i have never had a locktite plug loosen up.. but i have seen thread damage from it..
so for you guys i recomend..
1. antiseize and proper tourqe and retighten as they loosen (if they do)
2. or just put them in the way ford does.. with no crap on them at all.. works fine and i have gotten them out with 150k plus miles on them..
we have more problems with iron head fords seizing the plugs... never had a problem with a aluminum head ford and a plug seizing.. the old 5.8 is known too have the plugs seize too the head.. and that a iron head..
maybe in the early days of aluminum heads there was seizing problems due too two different metals reacting over time.. but this has LONG been worked out..
1 of 2 Next Last
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
KNOCK WITH CLUTCH OUT
  • Scwhitten
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
U
8 Years of Vibration leading to engine knock?
  • UpgradeXP
  • Apr 14, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 14, 2025
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
