  • SN95 4.6L Mustang Tech
Engine Light/ 02 Sensor
  • Thread starter Thread starter Damon7278
  • Start date Start date Jan 17, 2010
D
Damon7278
Fort Lauderdale
Jan 17, 2010
  • Jan 17, 2010
Recently my car turned 98,000 miles and i changed out the belt and air filter since it needed it, pcv value was also changed, when I got into my car, the service light was on and at a half of a tank, I only made a few trips and by the end of the night when I got home from work, I was a quarter of a tank, I believe it is my sensors and if it is, I already have a place to take it, mustang specialities in pompano, my question where can I go to get a reasonable price on them and my stang (02 GT), I believe I have 2, one in the front and one in the back, need help quick please
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jan 17, 2010
  • Jan 17, 2010
Is your question only looking for where to take your car for service or are you trying to figure out how to fix it yourself?
Why do you believe it is a sensor problem?
Note, the rear O2 sensors do not affect drivibility. They are there only to monitor cat function. If replacing O2 sensors for a drivabilty concern, replace the fronts ones.
If you would like help diagnosing the problem, please post the complete DTC codes. Most any autoparts store will read the codes for free. Will need a complete explanation of all modifications as well as what has been done to resolve the issue.
Good luck.
patman0911
2,287
Tuscaloosa, AL
Jan 17, 2010
  • Jan 17, 2010
You've got 4 O2 sensors - a pair in the front and another pair after the catalytic converters. However, you really need to get the codes pulled because the light could be for any number of things other than bad O2 sensors. Many parts stores can read them for you for free.
WMburns types faster than me
  • Gulftown980x
  • Jul 29, 2026
squeak93
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
M
02 Sensor Wiring Problem
  • mpence
  • May 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 14, 2025
mpence
M
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
M
Aftermarket Brake light help needed
  • Mustang Steve
  • Mar 17, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 17, 2026
Mustang Steve
M
