Engine light
223 was one of the codes. I guess I need to replace module. Thanks Guys. Also 23 came up which is the tps. The repair manuel says something about not replacing this on your own because it has to recailbrated when a new one is installed. Anyone heard of this?
What kind of manual have you been looking at? Must be a Haynes or Chilton. :rolleyes:
The TPS is usually adjustable(although some are not and have to be modified so they are). All you have to do is set the new one to the right voltage spec at closed throttle.
